Nav Disk?
tnpartsguy
Nav Disk?
Post by tnpartsguy »
Anyone got one? Is it copyable? I need one very badly for a customer.Part # 88973742 is what I have been given, it's for a 2005.
tnpartsguy
*bump*
tnpartsguy
Re: Nav Disk? (tnpartsguy)
OK, let me try again....anyway that someone could take their Nav Disc and scan it so I can see if it IS the Toyota disc, and what the part # is?
Jahntassa
Post by Jahntassa »
The disc is probably the same for the Matrix and Vibe, but it is not a Toyota disc. IE, the Lexus Nav discs will not work with the Vibe NAV.I think in theory the disc can be copied using a dual-layer burner, but I sold my NAV setup around two years ago, so I don't have the disc..
justin0469
Post by justin0469 »
I was reading about this on other forums. I did read that one person successfully copied a GM nav disc but it required alot of work and patience and even buying a different DVD burner then that specific person had. Going to http://www.gmnavdisc.com gives the part numbers for specific cars and prices (I was shocked at the price! $199) Or their number is 877 628 3472 Dealerships may get them cheaper (hook me up! )
