03 to 04 ecu upgrade?
FlynHwian
Post by FlynHwian »
I've heard in some places on the forum that from the 03 model year to the 04 model year the Vibe GT was detuned for emission requirements.SO replacing an 04 ecu with an 03 ecu would lower the lift engagement and gain some hp back. Is this true or am I on crack, cuz I can't find the posts anymore. *Edit* Also, would it just be plug and play, cuz this seems like the ultimate cheapo ecu upgrade out there...
BlueCrush
Re: 03 to 04 ecu upgrade? (FlynHwian)
Post by BlueCrush »
Quote, originally posted by FlynHwian »Is this true or am I on crack, cuz I can't find the posts anymore.BOTH! I know some guys on NewCelica.org have done it to their GT-S's. I thought a couple people did it on MO to their Matrix XRS's. I did a search on there but their search engine sucks so nothing came up in the results that I could find. I would pose the same question on MO. Good Luck.EDIT: Upon further research I found this thread on MO from "thebarber"http://matrixowners.com/forums...05&hl=
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
FlynHwian
Post by FlynHwian »
...two words...Next Mod
BlueCrush
Post by BlueCrush »
...one word...Cool!
My Fleet:
northvibe
Post by northvibe »
Yeah 03 ecu lower lift fpm kick in easy mod for cheap thrills
goodvibe
Post by goodvibe »
I had an 03 so I'm biased but that swap is a mixed blessing. The peak HP was virtually identical when dynoed and the 04 actually has a stronger torque curve below lift and timed as fast or faster in sprints. Lower lift is great but being stronger below is probably more important. It would be nice to have both. Changing to an 04 or 03 ECU from later years seems very worthwhile but the 04 for 03 swap is iffy.
