80,000 Miles And I Havent Changed My Belt ..YET
VibeTronic
Post by VibeTronic »
Should I Change My Belt NOw ..Even Though It Shows No Signs Of Breakage? My Belt Tensioner Is Making Noise Though..
VIBETRONIC IS HER NAME AND SPEED IS HER GAMEFlOriDa MeEt FaLl 2007??? 2003 Frosty VibeNew Paint JobNew GM Rocker Moldingz20% TintHID Fog LampsApc ExhaustMotegi FF7 Rims 101,800 Miles VIBES GET BETTER WITH AGE..Pontiac.!
CAN-AWD-VIBE
Post by CAN-AWD-VIBE »
No cracks? or nics after that long... must be a record.you are going to have the belt off when you change the tensioner.... might as well swap it out now.Or leave it til it shows signs of "breakage"but then you will need a tow truck.whatever turns you on.
CAN-AWD-VIBE03 Neptune AWDInjen CAI, Hotchkis springs, custom magnaflow exhaust w/4" tip, tint, window deflectors, stubby antenna, 3pc Mr. Grille, foglight conversion mod, Grafxwerks front & steering wheels overlays, Injen oil cap, strut tower brace, P225/45R17 Michelin Pilot Sport A/S, 17" ADR Sokudos
zionzr2
Post by zionzr2 »
I would say switch it and hold on to it as a spare in case you do get a bad belt in the future.
VibeTronic
Re: (zionzr2)
thnx...i may just go on ahead and buy a new belt..but iis it hard to get on and off...?
shryocdj
Re: 80,000 Miles And I Havent Changed My Belt ..YET (VibeTronic)
Post by shryocdj »
are you guys talking timing belt?
Re: 80,000 Miles And I Havent Changed My Belt ..YET (shryocdj)
no, the serpentine accessory drive belt. Vibes/matrixes have timing chains, which last a lot longer than timing belts.http://forums.genvibe.com/zerothread?id=16476 has JohnC's tips on changing the belt.
shryocdj
Re: 80,000 Miles And I Havent Changed My Belt ..YET (joatmon)
Post by shryocdj »
really good to know thanks muchand as far as the tensioner, is that something that routinely gets replaced also? or is it just due to his making noise?
2002sportside
Post by 2002sportside »
The serpentine belt tensioner only needs to be replaced if it develops a problem.As for the belt change... not hard at all. Should take 5-10 minutes to do.
2005 Moonstone Base Vibe 38k as of October, 2010 (41k as of 7-15-11)Moon & Tunes, power package, automatic, center console power port added
