03-04 matrix/Vibe Gauge Cluster work in 06 Vibe?
silvrhawk7
Post by silvrhawk7 »
I'm not sure if this has been brought up before or not, but was curious if the gauge clusters were interchangeable between years or did GM change the wiring harnesses around between years (like they usually do).Let me know either way..- Q
In Memory, taken too early in a rear end collision
Sunrise: June 2006, Sunset: Jan 2015 :cry:
Miles 129,000
2006 Silver Mono, Base 4-Speed auto.
In Memory of Pontiac Motor Division 1926-2010
In Memory of the Pontiac Vibe 2002-2009
GrayFox
Re: 03-04 matrix/Vibe Gauge Cluster work in 06 Vibe? (silvrhawk7)
Post by GrayFox »
this thread has some good info about the differenceshttp://forums.genvibe.com/zero...age=2read the last post by joatmon http://forums.genvibe.com/zerothread?id=7692[/QUOTE]This has been talked about. The main problem is getting the odometer reset. I've never heard of anyone wanting the 03 cluster. 03s are the only year with the "all red" in 04 they started with the white numbers
silvrhawk7
Re: 03-04 matrix/Vibe Gauge Cluster work in 06 Vibe? (ANO_Vibe)
Thanks for the info, Just noticed that i posted in the wrong forum sorry about that
Miles 129,000
you can swap an 03 and an 04, but the 05+ has an extra connector, for extra signals and indicators that the 03/04 cluster can not support.
DopeVibeGT
Post by DopeVibeGT »
Quote, originally posted by ANO_Vibe »This has been talked about. The main problem is getting the odometer reset. I've never heard of anyone wanting the 03 cluster. 03s are the only year with the "all red" in 04 they started with the white numbers I actually think the all red looks more like a Pontiac.
Kari
Re: 03-04 matrix/Vibe Gauge Cluster work in 06 Vibe? (DopeVibeGT)
Post by Kari »
Quote, originally posted by DopeVibeGT »I actually think the all red looks more like a Pontiac. Me too. I love my red gauges.
GenVibe Global Moderator
silvrhawk7
Re: 03-04 matrix/Vibe Gauge Cluster work in 06 Vibe? (joatmon)
Quote, originally posted by joatmon »you can swap an 03 and an 04, but the 05+ has an extra connector, for extra signals and indicators that the 03/04 cluster can not support.Thanks for the info everyone....I know i dont have like the safe and sound package (or many accesories for that matter) I will have to research a little more.I may just go find an IP Cluster at the junkyard and have an LED mod done to it...
Miles 129,000
