Key won't open door
chadmt
Key won't open door
Post by chadmt »
My remote to my 2003 Vibe is working fine, but I actually tried to use my key to manually open my doors and it would not open either the driver, passenger door, or hatch. I tried my regular and spare key. Anybody have any ideas? Do I just need to apply some WD40? I had not tried to use my key in quite a while.
BlueCrush
Re: Key won't open door (chadmt)
Post by BlueCrush »
Welcome to GenVibe! WD-40 should work. Let it soak for a while then try it again. Re-apply if needed. Just be prepared for it to spray back out of the keyhole at you, so don't put your face down there when you spray. Or better yet throw on some safety glasses/goggles. You eyes will thank you later. Also, make sure you have something ready to wipe it off the paint, asap. Good Luck! Let us know how it works.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
Has that key ever opened the door?
BlueCrush
Re: Key won't open door (joatmon)
Post by BlueCrush »
Quote, originally posted by joatmon »Has that key ever opened the door? Oh, didn't catch that! Yeah, maybe the locks were changed out at some point if it doesn't work in any of them.
My Fleet:
Baltovibe
Post by Baltovibe »
Quote, originally posted by chadmt »I had not tried to use my key in quite a while.Quote, originally posted by joatmon »Has that key ever opened the door?I originally thought the same thing, but he did imply that he had used the key before. And, apparently the same key can be used on the ignition.I have a car with remote that I use all the time. When I tried to use the key on the door locks and trunk recently, they were locked up. I guess the tumblers get stiff from lack of use. Solution was liquid graphite used for locks.
redlava
Re: Key won't open door (Baltovibe)
Post by redlava »
Are you sure you have the right car?Hey it happened to me once.Don't make faces.
chadmt
Post by chadmt »
Yeah... it has opened the door in the past. Am just so reliant on the remote that I rarely have used the key to open the door. But you never know if the remote battery might decide to give up when you are in the middle of Timbuktu. I will try the graphite!
locks stiff from lack of use is a lot better than someone getting a Vibe and having the ignition lock keyed differently than the doors, which would prompt the question "which locks were replaced, and why?".Welcome to genvibe!
