My '04 Vibe is still only two weeks old to me. But, I had a tire shop check the tire pressure a day after bringing it home; just to be sure the dealer had the right amount in them. All the stem caps were loose so I figured they must have done it. The tire shop said they were all at 32 psi, which is correct. I was a happy camper.Yesterday while washing it, it seemed the driver side front tire was low. The tire gauge I had in my toolbox was giving irratic readings, so I went out and got a better one with the needle gauge instead of the type with the popout stick. Sure enough they were all low, with the one I noticed 10 pounds low. Took it down to the corner station and filled them all to 32 psi as recommended. I'll never trust anyone else to take the readings again!I was trying to do everything right, and driving real easy on my first tank of gas so I could get a good estimate of the MPG. It got 29 MPG on my first true fill-up with mostly city driving. But, with low tire pressure all around it probably got less than possible.
2004 Base Shadow MonotoneMoon-n-Tunes, Power Pkg16" Alloys, AT, ABS, Side Air-bagsPin-stripe, 30% Tint, Fat exhaust tipMy GenVibe Garage
not bad for low tire pressure and for CITY driving.. WOW.If i get 29mpg with my awd I am thrilled... lol I only hit 32mpg once .. and that was all highway driving.
Yeah, I thought 29 was pretty good too. I can't wait for a long trip to see what the highway mileage will be. Now that I think of it, the tires may have been a little hotter when they checked the pressure. Not sure about the one that was way low though. I might have a valve leak or something.
i would suggest you check your spair as well... I checked my wifes over the summer, its a 2000 cavalier.. I don't think anyone has check it before, fact is I am sure no one checked it before... it was at 3psi... it's soposed to be at 60psi
