Oil drain plug
MikeMLS
Oil drain plug
Post by MikeMLS »
anyone change the oil yet themselves? does the Vibe have a magnetic oil drain plug?
cruizin gt
Re: Oil drain plug (MikeMLS)
Post by cruizin gt »
I changed my oil not too long ago, and nope, it does not have the magnetic drain plug.
NSimkins
Global Moderator
Post by NSimkins »
quote:does the Vibe have a magnetic oil drain plug?What exactly is this?
NovaResource
Re: Oil drain plug (NSimkins)
Post by NovaResource »
A magnetic drain plug is exactly what it's called: an oil drain plug that is magnetic. What it does is attract small metal particles that get into the oil as teh engine wears. When you pull the drain plug out to change the oil, the metal particles come out with it. Just clean the plug and reinstall. It's just an extra piece security in addition to the oil filter. I have one in my Nova. I also have a magnet in my Novas transmission pan and the rear axle housing cover.
esjones
Re: Oil drain plug (NovaResource)
Post by esjones »
Wouldn't this be of little value in an aluminum engine?- Earl
- Earl Earl Jones, Sales and MarketingHorizon Systems LLChttp://www.horizonsystems.com/ Skype ID: esjonesMy Vibe: '03 Base, 5-speed, ABS, Alum. Wheels, Power Pkg, DVD Nav., Security, Neptune/Graphite
NovaResource
Re: Oil drain plug (esjones)
The block and head are aluminum but not the entire engine. Plus, aluminum blocks have steel cylinder sleeves and rings. Aluminum would wear too quickly and does not seal as well.
