Transmission Synchrnizers
asiankid624
Post by asiankid624 »
I have a 2003 pontiac vibe and in when i shift to 3rd gear it grinds, but if i slowly ease it in third it doesnt grind. I am curious what is wrong and what parts do i need to fix it thanks
CAN-AWD-VIBE
Post by CAN-AWD-VIBE »
seach tool is your friend... or worst nightmare come true.search 5rp tranny or something along those lines.sorry
CAN-AWD-VIBE03 Neptune AWDInjen CAI, Hotchkis springs, custom magnaflow exhaust w/4" tip, tint, window deflectors, stubby antenna, 3pc Mr. Grille, foglight conversion mod, Grafxwerks front & steering wheels overlays, Injen oil cap, strut tower brace, P225/45R17 Michelin Pilot Sport A/S, 17" ADR Sokudos
DavidPIL
Re: Transmission Synchrnizers (asiankid624)
Post by DavidPIL »
Hey...Do you have a GT or Base? As CAN-AWD-VIBE eluded to, there are many posts about the 5spd issues and some about the 6spd. I have the 6spd and the gears have always been clunky, sometimes a grind going into R, 1,3,5. I have tried a variety of gear oils (from Mobil One 75w90 to Redline 75w90 and 75w80) the Redline MTL is what I have in there now and it's quite smooth through the gears when it's warm but I still get an occasional clunk.I sometimes thought, at least in the 6spd, that it was the motion from going <down-left> to <center-up> which caused the clunk/grind. I do notice the grind doesn't happen (or maybe I don't notice it) when going from 1st to 2nd or 3rd to 4th. In any case, you could try a full synth gear oil (I don't recommend the Mobile One for cold temps) or just read some of the other posts to see what is discussed there.Dave
asiankid624
Re: Transmission Synchrnizers (DavidPIL)
ive searched all over the internet thats why i i came to this forum
asiankid624
its not gt and its fwd
Quote, originally posted by asiankid624 »ive searched all over the internet thats why i i came to this forumlol they mean use the search tool wtihin the forum:top right corner, under the ads, is a link:SEARCH
CAN-AWD-VIBE
glad you searched and found us here... now it's time for you to search inside our site for you answers. (search "5 speed")You have an internal tranny problem and they are well documented on this site.Your thread title pretty much sums up your repairs You will probably need to rebuild or replace the tranny, and you might as well take care of the clutch at the same time.again sorry about the bad news.
I have a 5 speed vibe, and have had tranny troubles, but never any synchro problems, and the only time I grind gears is when I get careless and mis-clutch. Not saying the grinding is your fault, just that I haven't had synchro problems in my vibe transmissions. Those of us here who have had tranny problems seem to lose bearings. How many miles on the car? Your symptoms sound synchro related. A gear oil change is the easiest and lowest cost potential fix, so I'd try that first. and welcome to genvibe
bradw
Post by bradw »
AsiankidDid you check your clutch fluid level?
