Water leak
SinisterMind
Water leak
Post by SinisterMind »
Few weeks ago we had heavy rain and I drove the Vibe through some deep water. When I got home I noticed water dripping from the bottom of the dash into the foot well area on both sides. Any idea how the water got inside? Cabin air intake maybe?
Re: Water leak (SinisterMind)
Quote, originally posted by SinisterMind »Few weeks ago we had heavy rain and I drove the Vibe through some deep water. When I got home I noticed water dripping from the bottom of the dash into the foot well area on both sides. Any idea how the water got inside? Cabin air intake maybe?Isn't from the fresh air intake. That's the cowl above the hood, below the windshield.Do you have a moonroof?It's *possible* (not likely though) that one or more of your drains is disconnected and draining into the car...Otherwise, not really sure how to explain that one, there's no logical reason for that to happen...
SinisterMind
Re: Water leak (ragingfish)
I do have a moonroof, but I think it's highly unlikely that that is the culprit. I have driven the car in heavy rain without any problems. This was the only time where I drove through deep puddles. I suspect the fresh air intake allowed the water to get inside.
CAN-AWD-VIBE
Post by CAN-AWD-VIBE »
you better check that cabin air filter then... that should be a little moist.also check all your fluids if you went through something that deep.
CAN-AWD-VIBE03 Neptune AWDInjen CAI, Hotchkis springs, custom magnaflow exhaust w/4" tip, tint, window deflectors, stubby antenna, 3pc Mr. Grille, foglight conversion mod, Grafxwerks front & steering wheels overlays, Injen oil cap, strut tower brace, P225/45R17 Michelin Pilot Sport A/S, 17" ADR Sokudos
Quote, originally posted by SinisterMind »I do have a moonroof, but I think it's highly unlikely that that is the culprit. I have driven the car in heavy rain without any problems. This was the only time where I drove through deep puddles. I suspect the fresh air intake allowed the water to get inside.how do you suppose the water got up and over the hood?and even if it were that intake, the floor vents are on the firewall. it still wouldn't be dripping from the dash.
