Quote, originally posted by CAN-AWD-VIBE »if it was a dodge i would say blower motor resistor... but im not really sure if its serviced serperatly on our vehiclesbtw- welcome to the site same applies to Vibes, Others have had the resistor go out, resulting in fan only working on high, the resistor is suppposedly relatively easy to replace.See http://forums.genvibe.com/zerothread?id=22539 and http://forums.genvibe.com/zerothread?id=23496
Welcome board! And I concur with the other blower resistor comments! Especially with the high speed only, that's the way they were designed to fail.Good luck getting it fixed and let us know if there is anything else you need. And stick around, it's a great place you found here.
Neptune/primer/rust
'21 Elantra Limited 2.0L/IVT
