K&N Drop in affects exhaust sound ?
hakune
Post by hakune »
Well went out today and got me a K&N drop-in filter.Took of the intake box and cleaned it out also took off the MAF and gave it a clean and did a ecu reset.To be honest i did'nt expect much result from it since the alterations are minimal but boy did it suprise me !!she runs a lot smoother now and has definitly found some horses somewhere even the exhaust seems to make a lot lower sound now.Had a laugh too when i used some air intake cleaner big old puff off soot on her first start ^^I'm quite happy now
BlueCrush
Re: K&N Drop in affects exhaust sound ? (hakune)
Post by BlueCrush »
Your improvement is more so from the MAF cleaning than the drop-in filter. The Drop-in will make your intake and exhaust only slightly louder and give you only a 1-2hp gain. Nice to see a small gain from a new filter and a little cleaning. I would recommend cleaning both once a year now to maintain maximum performance.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
hakune
Post by hakune »
Yep cleaning your MAF should definitly be a more "mainstream" service procedure (as in everybody should do it)Wondering now if i should run through a bottle of injector cleaner (My vibe being pre owned and all)already changed all the fluids in her
BlueCrush
Re: (hakune)
Post by BlueCrush »
Wouldn't be a bad idea.
My Fleet:
CAN-AWD-VIBE
Re: (hakune)
Post by CAN-AWD-VIBE »
get an injector flush at a dealer... dont waste your money on fuel system additives.They are good "maintenance" but if you are concerned about getting the system clean do a proper inj flush.
CAN-AWD-VIBE03 Neptune AWDInjen CAI, Hotchkis springs, custom magnaflow exhaust w/4" tip, tint, window deflectors, stubby antenna, 3pc Mr. Grille, foglight conversion mod, Grafxwerks front & steering wheels overlays, Injen oil cap, strut tower brace, P225/45R17 Michelin Pilot Sport A/S, 17" ADR Sokudos
GMJAP
Re: (hakune)
Post by GMJAP »
Quote, originally posted by hakune »Yep cleaning your MAF should definitly be a more "mainstream" service procedure (as in everybody should do it)Wondering now if i should run through a bottle of injector cleaner (My vibe being pre owned and all)already changed all the fluids in her How do you recommend cleaning the MAF?
BlueCrush
Re: (GMJAP)
Post by BlueCrush »
1. Disconnect Battery2. Remove MAF Sensor3. Spray w/ MAF cleaner (can get at any auto parts store)The amber bulb is the air temp sensor you should also spray the two silver wires that are up inside.4. Let it air dry (evaporate)5. Reinstall MAF Sensor6. Reconnect Battery
My Fleet:
hakune
Post by hakune »
I'd also reccomend to clean the throttle valve & body with some Air intake cleaner.mine looked all grimed upshould have taken some pictures >_<
jasonvibe
Re: (hakune)
Post by jasonvibe »
The MAF is way before things get dirty in the intake past the PCV. So cleaning may help a little. But what do you clean it with?
hakune
Post by hakune »
Just got some MAF cleaner and intake cleaner at NAPPA
