Tach Feed ECU Pinout
FlynHwian
Post by FlynHwian »
Just wondering which wire on the ECU is for the ECU readout.I just recently purchased a shift lamp and it runs best if you give a direct feed from the ECU and it didn't come with any wiring schematics. Now ive seen the ECU readout pdf file but im still confused, has anybody else put an aftermarket shift lamp on their Vibe GT (2zzge)?
Celtic_Curse
Post by Celtic_Curse »
Search for this topic. I know its on here I used it to instal my shift light too.
2003 Supercharged 5spd Vibe BaseGM Supercharger + TRD ECUMagnaflow Cat Back + DC Sports Header 18" AXIS rimms w/Kumho TiresTop Spoiler + Vis CF Functional Scoop
Re: (Celtic_Curse)
Quote, originally posted by Celtic_Curse »Search for this topic. I know its on here I used it to instal my shift light too.http://forums.genvibe.com/zerothread?id ... 77searched titles for shift light
satur9
Re: (joatmon)
Post by satur9 »
i was searching for shifltlight info as well. on autometers web site it says pin 27 black wire is the tach feed on the instrument cluster harness for tach. save you from running all the way over to the ecu.
Celtic_Curse
Thats where I wired mine into.
