Double Din dash kit
shane_c
Double Din dash kit
Post by shane_c »
I was looking at the Kenwood DPX 301 and 501. Does anyone have one of these? Who makes a dash kit for the double din receivers? Only ones I seem to be able to find is for single din.
2006 Vibe (base) - Platinum Silver, 5 spd, ABS, Power Package, Infinity Speakers, Dynomax muffler, Cosmo SR intake - SOLD
audiovibe
Re: Double Din dash kit (shane_c)
Post by audiovibe »
here is the kit I used (it was used for a iva-d310 on top and a zapco dsp sl on the bottom) just remove the piece that goes across the middle and you are set. the item number is BKGMK422 http://bestkits.com/ViewImage....2.jpgAron
Jahntassa
Post by Jahntassa »
You don't really need a kit for a double-din radio. The only thing it does is cover up the space on the sides since we have a 'wide' double-din space. The Metra kit also supports double-din radios.I know some, like a recent JVC model I can't remember, had a piece of plastic that went around it for cases like this.Since our dash is toyota, it's technically an ISO mount, not a DIN, so the radio is actually secured into brackets instead of just attached in the dash.
Celtic_Curse
Post by Celtic_Curse »
WE can put a double Din in our radio spots???? I thought we had a 1.5 din slot??
2003 Supercharged 5spd Vibe BaseGM Supercharger + TRD ECUMagnaflow Cat Back + DC Sports Header 18" AXIS rimms w/Kumho TiresTop Spoiler + Vis CF Functional Scoop
Mrizzle05
Re: (Celtic_Curse)
Post by Mrizzle05 »
I cant post pictures yet... but i got a doubledin to fit in my vibe. its a lcd touchscreen. and it has maybe an 1/8" left on top and bottom.but the sides have about 1/4-1/2" on either side.The kit im using is a secretly made one that im working with. *hehe*But it does fit in there.
