I have a 2003 moon and tunes and a sub lying around. I'm wondering if it's possible to just run the sub through the factory amp. I know it wouldn't sound the greatest, but it's the cheapest.
Yes, just get a scosche line converter from Wal-mart for $20 and a wiring kit and hook everything up. Mine was like that for a while before I got all new amps, speakers, etc...
That would be a no. The 2003 M&T doesn't have provisions for a sub.You would need a seperate amplifier for that sub, THEN the wiring kit and line converter to make it work. If you just have a 'bare' sub with no amplifier, you cannot power it off the M&T amplifier.
Quote, originally posted by Jahntassa »That would be a no. The 2003 M&T doesn't have provisions for a sub.You would need a seperate amplifier for that sub, THEN the wiring kit and line converter to make it work. If you just have a 'bare' sub with no amplifier, you cannot power it off the M&T amplifier.Oops, you're right, I had an extra amp when I did that. That was what the wiring kit was for! I just used to converter to get the signal for the sub amp from the M&T amp. Thanks for the correction!
Quote, originally posted by damronjr »Oops, you're right, I had an extra amp when I did that. That was what the wiring kit was for! I just used to converter to get the signal for the sub amp from the M&T amp. Thanks for the correction! Yeah, I kinda gathered that's what you had done.
