I need to know how the door side molding's are atached to the body? (clip's or double side tape) Also anybody have pic's with them off (removed).... nuvibe
it uses clips and double sided tape. If the cladding is popped off anywhere, than the clips are generally busted. So you can buy some at the dealer and they will will give you some double sided tape also to put along the top edge of the cladding.
Thank's, I was planing on taking them off to give more a smooth look. But then I'd have to weld up the hole's and that's to much trouble. They stay on..... nuvibe
