Household plug
tomspec
Household plug
Post by tomspec »
What is your FAVORITE use for the household plug in the Vibe?
Re: Household plug (tomspec)
I've used mine for a laptop, razor, an AA batteriy charger, a soldering iron (while working on the car )During some protracted power outages, I've also run an extension cord into the house to power my woodstove fan, a TV, and also my cable modem and wireless router (but not all at the same time)Hard to fit all that into a single poll voteThere's another thread I remembered, SAYSF, but it's not a poll : http://forums.genvibe.com/zerothread?id=193
zionzr2
Re: Household plug (joatmon)
Post by zionzr2 »
100 watts goes a long way!!!
GMJAP
Post by GMJAP »
Quote, originally posted by tomspec »What do you use your household plug for?This poll is problematic because each member only gets 1 vote, but may use the 110 outlet for multiple things.
binary
Re: Household plug (GMJAP)
Post by binary »
Quote, originally posted by GMJAP »This poll is problematic because each member only gets 1 vote, but may use the 110 outlet for multiple things."What is your FAVORITE use for the household plug in the Vibe?"
tomspec
Re: Household plug (binary)
Post by tomspec »
That's my fault. I edited and changed it from "what do you use it for" to "what is your favorite use."
Mase
Re: Household plug
Post by Mase »
One time we had church service outside in a park. When I got there I saw a PA system and amplifier plugged into a 100' extension cord running into a Vibe!
whatthefunk41
Post by whatthefunk41 »
i also use it to charge my fone cuz im to lazy to buy a car charger
AKLGT
Post by AKLGT »
used it for the laptop when we drove the vibe up from Ontario.
AKLGT1998 Subaru 2.5RS
vibebob
Post by vibebob »
how do y'all plug laptop's into the outlet ? my work has one, but the plug on the AC adapter is the three prong type.
no longer a vibe owner"Peace cannot be kept by force. It can only be achieved by understanding." Albert Einstein.
kostby
Post by kostby »
Use an old-school gray 3-prong to two-blade (polarized) adapter. Works just fine! I'd post a pic but the adapter is out in the car and it's 3 AM!
BuzzDog
Re: (kostby)
Post by BuzzDog »
I use my laptop with a GPS sensor and mapping/tracking software when I'm working on the road; I fold the front seat forward and secure the laptop to the seatback with a ratchet strap. Like the previous poster, I use an old-school three prong adapter. Saves me from having to worry about my battery, plus I have my laptop display set up to default to full brightness when it's plugged in...MUCH better for daytime use.
BuzzDogLocated in beautiful Northwest Arkansas2005 VibeFrosty • Moons and Tunes
Emerica13
Post by Emerica13 »
Quote, originally posted by joatmon »I've used mine for a laptop, razor, an AA batteriy charger, a soldering iron (while working on the car )During some protracted power outages, I've also run an extension cord into the house to power my woodstove fan, a TV, and also my cable modem and wireless router (but not all at the same time)Hard to fit all that into a single poll voteThere's another thread I remembered, SAYSF, but it's not a poll : http://forums.genvibe.com/zerothread?id=193How can you solder wiring on your car with it? If you're soldering wiring, the battery should be disconnected, but even if you dont disconnect it, it certainly shouldnt be powering anything while you're messing with the wiring. just wonderin
2003 Shadow Vibe GT
BuzzDog
Re: Household plug (Emerica13)
Post by BuzzDog »
He may have been soldering something other than the wiring...or perhaps soldering a ground connection on something while the hot lead was disconnected. May be a stretch, but it could be so...
northvibe
Post by northvibe »
the salemans at the ponti dealer told me i could use it for my blow dryer...i thought he was retarded and just looked at him like a idiot. a blow dryer would 99% likely blow or trip the fuse....uh salesman oh yea...WTH do i need a blow dryer for!
prtlnd03gt
Post by prtlnd03gt »
i use a glade plug in
BuzzDog
Re: (northvibe)
Post by BuzzDog »
Quote, originally posted by northvibe »a blow dryer would 99% likely blow or trip the fuse...Well, I shave my head, so the salesman knew better than to mention that use to me. But I'll guarantee that using one in the recepticle will trip the built-in circuit breaker (which automatically resets itself). The recepticle is rated at one amp...a 1200-watt blow dryer draws about 10 amps (1200 watts divided by 120 volts equals 10 amps).
prtlnd03gt
anybody know if it would be possible to plug in a powered sub for a computer...
Re: (prtlnd03gt)
If it doesn't exceed 100w, youbetcha
Neptune/primer/rust
'21 Elantra Limited 2.0L/IVT
Re: (kostby)
Quote, originally posted by kostby »Use an old-school gray 3-prong to two-blade (polarized) adapter. Works just fine! I'd post a pic but the adapter is out in the car and it's 3 AM!Here ya go kostby:If anyone's wondering, the outlet is a nice way to power a dremel too!
NascarXprt
Re: (ragingfish)
Post by NascarXprt »
i just use it for when i need to charge my cell phone.
Mugen
Post by Mugen »
Hmm, glade plugin. That's really a great idea, always have my car smelling fresh!
chemrebel
Re: (Mugen)
Post by chemrebel »
i just used the plug today for the first time since i've had my vibe.i have a 30 minute commute to work and we were having a thanksgiving potluck. so i whipped up some green bean casserole in my crock-pot, plugged my crock-pot into the plug and away i went.
Chemrebelproud owner of The Coolest Mom-Mobile Ever! 2005 Vibe Base Lava MonotoneCustom Mom-Mods: Installation of Cosco Scenara and Graco Snugride car seats
