basically you know what im asking just have no idea how to do it. ive got a 2006 vibe with M&T. is there anything i can do as far as MORE Bass?? THANKS!!
no header, K&N Typhoon SRCustom Red Painted Engine W/ Black Lettering, Monsoon Sound Sirius Satalite Radio, Xm Satalite RadioRed Led Underdash Glow/ Spotlight on Vibe Symbole, Red Grill LightsRed LED Wireless Remote Controled Underglowhttp://www.cardomain.com/ride/2402619
Funny you should ask - I'm planning the same thing.What I plan on doing is re-routing my sub's audio lines to my amp's speaker line input (or you can use an adapter that will change a line input to RCA output).I plan on using some relays to allow me to switch between the two... but so far, I'm still working on the planning stages.
Yes you can. If your amp has high level inputs, you just have to tap into the high level outputs from the amp under the seat. That is what I did when I connected my Bazooka with a built-in amp. I don't recall which exact wires I tapped into since it was a while back. Here is my old post from my install: http://forums.genvibe.com/zerothread?id=18348 Here is a thread that may be helpful and has a link to the wiring diagram: http://forums.genvibe.com/zerothread?id=17810 I'm not sure if they changed the amp in the 06 model, might need to search on that.
Justin 2003 Vibe GT - Mille Miglia Evo5 18x8 Wheels (now stock)- Magnaflow Cat-Back Exhaust (now stock)- Tein S-Tech Springs (now stock)- Injen CAI - Red Painted Calipers - Hella Supertone Horns - Polk Speakers - Bazooka RS8A-HP Sub - Kenwood Headunit - Still love my Vibe, but I've just turned it back into a basic daily driver.
