Just wondering if anyonw knows, Can or if, you change the window switch on the drivers door to make the passenger side window open with one touch like the drivers?
untill the mystry window shatter issue is solved by GM, i do not see this as a wise choise.but i'm sure it can be done. the wire hackers will have to chime in though.
