Can't access chat.
Let us know of any problems, suggestions, or questions you have about the GenVibe Website and Forums
GMJAP
Can't access chat.
Post by GMJAP »
I can't get into the chat room, either from my machine at work or home. I get the following unhelpful error. Any ideas what might be the problem?thanks
GMJAP
Re: Can't access chat. (GMJAP)
Post by GMJAP »
*bump* help!
BlueCrush
Post by BlueCrush »
I was able to log on fine. Might be your settings. (whatever those are)
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
redlava
Re: Can't access chat. (BlueCrush)
Post by redlava »
The only way I can get into the chat is if I use Explorer. Firefox won't work for me at all. So I guess you could try that.
BlueCrush
Post by BlueCrush »
I'm using Opera 9 by the way with no problems.
My Fleet:
GMJAP
Re: Can't access chat. (redlava)
Post by GMJAP »
Thanks for the tips.I'm using Explorer, and I used to be able to login no problems. Now I can't from either work or home.Could this be a firewall thing? ADMINS- does it use any different ports?
millster
Post by millster »
The most important thing to note here is that this is NOT actually hosted as a part of Genvibe. We really have no control over it.Standard HTTP port though. It's just a Java applet hosted on a regular website.My suggestion would be to try removing/reloading Java VM on your computer. Uninstall as you would any application and then download it from:http://www.java.com/en/download/manual.jsp
-Millster-
2006 Toyota Matrix XR
1995 Saab 9000CSE 2.3T
GMJAP
Re: Can't access chat. (millster)
Post by GMJAP »
OK, it definitely is a firewall issue. I put the firewall here at home down to low, and could connect no problem.There must be something different from the standard HTTP port....
looks like loading the applet uses some random port, but logging in and sending lines seems to consistently use TCP port 8002
GMJAP
Re: Can't access chat. (joatmon)
Post by GMJAP »
Quote, originally posted by joatmon »looks like loading the applet uses some random port, but logging in and sending lines seems to consistently use TCP port 8002THANK YOU! Just needed to change my firewall script to allow port 8002.
Vibe_dude
Post by Vibe_dude »
Where can u log into this chat room....i dont see a link on the site anywere.
NSimkins
Global Moderator
Re: Can't access chat. (Vibe_dude)
Post by NSimkins »
Quote, originally posted by Vibe_dude »Where can u log into this chat room....i dont see a link on the site anywere. http://forums.genvibe.com/zerothread?id=21783Link is in first post of the thread linked above.
Vibe_dude
Re: Can't access chat. (NSimkins)
Post by Vibe_dude »
Cool......wow did not see that at all.......thx's
