Question.....
dreamer72fem
Question.....
Post by dreamer72fem »
Ok I have a question. Is there any way at night that you can sit in the car with the motor running without the lights being on? I have tried the emergency brake and doesnt work at night. ThanksStacey
Kari
Re: Question..... (dreamer72fem)
Post by Kari »
The E-brake should work at night if you have the E-brake engaged when the car is started. At least that's how mine works. When you release the E-brake, the lights will come back on. Mine is an '03 and I know the '04s and up have a different headlight module but I'm pretty sure this function is the same.
GenVibe Global Moderator
mcgusto82
Re: Question..... (Kari)
Post by mcgusto82 »
not if it's a stick. lights on no matter what.
Quote, originally posted by Kari »The E-brake should work at night if you have the E-brake engaged when the car is started. At least that's how mine works. When you release the E-brake, the lights will come back on. Mine is an '03 and I know the '04s and up have a different headlight module but I'm pretty sure this function is the same.I think the 03 and 04 worked that way, but my brother's 05 doesn't , the ebrake doesn't help, so I did the "put a switch in the red/white wire" mod to his
GMJAP
Re: Question..... (joatmon)
Post by GMJAP »
I think in the 05 plus, the e-brake will prevent the DRLs coming on, but there's no stopping the headlights when the auto sensor wants to turn them on.Try standing a flashlight on top of the sensor ?
Shadow-Vibe
Post by Shadow-Vibe »
My 03 the e-brake will work, but on the wife's 04 the lights are on no matter what.
jwalcik
Re: Question..... (GMJAP)
Post by jwalcik »
Quote, originally posted by GMJAP »I think in the 05 plus, the e-brake will prevent the DRLs coming on, but there's no stopping the headlights when the auto sensor wants to turn them on.Try standing a flashlight on top of the sensor ? the ebrake never seems to stop my DRL's from coming on. is that a difference between the auto and manual models?
2005 vibe gt
