Place to Ground Amp?
Travg73
Post by Travg73 »
Hello, I need to know a good place to ground my amp ('03 Vibe). Can anyone help?
Mrizzle05
Re: Place to Ground Amp? (Travg73)
Post by Mrizzle05 »
is your subs and amp in the back hatch area? wheres you location gonna be. i just grounded mine to one bottom of the bolts under the plastic access pieces where the spare tire is.sorry if that seems confusing. ill try and find a pic to show you.
AKLGT
Post by AKLGT »
yep, super easy if it's in the rear hatch.
AKLGT1998 Subaru 2.5RS
Travg73
Re: Place to Ground Amp? (Mrizzle05)
Post by Travg73 »
thanks for the reply, the box is in the hatch area. How did you get the wire under there?
AKLGT
Post by AKLGT »
the plastic parts unbolt. also, you can take that top off right behind the rear seats. it's another area to put more things.
Mrizzle05
Re: (trdvibe)
Post by Mrizzle05 »
there is a pic i uploaded here... it shows that rectangular cover up with the ground wire for my capacitor which is for the amp...
damronjr
Re: (Mrizzle05)
Post by damronjr »
Make sure you grind down the metal/paint to get a good ground on both sides of whatever you are putting it between.
