Finally had the time to install the set of 4- Tein Basic Damper Coilovers I ordered last month. Installation was fairly straightforward (with some minor help from the MO crew), similar to a normal spring swap. I set the height to the recommended level from Tein - the drop equals that of the Tein S-Tech springs I had on previously (around 2.2"-2.4"). With the Basic Damper setup, the only adjustment is height compared to the height AND damper adjustments on the Tein Super Street Coilovers. I chose the Basic setup since I wasn't too interested in the dampening adjustment, they were a little cheaper than the Super Street model, and I wanted the height adjustment as well as the new spring/shock absorber setup ultimately.The ride is definitely improved - less bounce on bumps and the suspension handles road imperfections much better than the stock shock/aftermarket spring setup I was running for a couple years.I've attached a pic of the rear setup finished with the new coilover. My other pics didn't come out too well since I only had my camera phone present. Other than that, the exterior appearance of my Vibe has essentially stayed the same so since the Vibe was dirty anyway, I didn't feel any additional pics were necessary. Next will be an alignment in a week or two once I finalize the ride height I want to stick with and everything has time to settle.
