Need some info
xLR8_Sd
Need some info
Post by xLR8_Sd »
I want to drop my vibe 1.5 inches to 2. but want some info first.to all that have done it already. did you just use springs? and if so what is a good brand? and do you need to get a camber kit if you go 2 inches? please reply with all the info you can. thnx
-BaseVibe/Neptune/Monopackage/Powerall/Auto/16Alum Rims/ActivePackage/RearWaterProofSeatCovers/LimoTintOnBack5.30%Front2- -Plans/1.5or2inch drop/17 inch Tenzo-r Mean6 rims/cool air intake-
NY Pete
Re: Need some info (xLR8)
Post by NY Pete »
Consensus seems to be Eibach ProKits for mild, safe drop, Eibach Sportlines for a more extreme drop. I've been told that TRD's springs are simply re-labeled Eibach ProKits, and Progress springs are not of very high quality (they continue to settle in and continue to drop too far out of spec).Looks like I'll be going with Eibach Sportlines once my Vibe arrives.
'02 Jetta 1.8T Silver Arrow/Black Leathuh - Neuspeed turbo inlet pipe, 17" VW Exor wheels, euro Bora tails, Neuspeed Sofsport Springs, Bilstein HD's, Da'lan hitch'03 20thAE GTI #3494 Imola Yellow/Black Recaros - Omori/AWE boost gauge, HPA Motorsports Short shifter, Neuspeed 28mm rear sway, REVO programming, Neuspeed turbo inlet pipe, FK Badgeless grille, Kamei eyelids and one big fat grin
xLR8_Sd
Re: Need some info (NY Pete)
Post by xLR8_Sd »
anyone have a link to a place with good pricing on them?
pissedoffgokart
Post by pissedoffgokart »
Coil overs. Coil overs, coil overs! Sorry, just had to put my .02 cents in! With coil overs you can adjust from 0-4 normally and can all but guarantee to get the drop you want!!!
MadBill
Re: Need some info (pissedoffgokart)
Post by MadBill »
I'm leaning towards the Tein S. springs:http://www.optauto.com/webstore/product ... &dept=1680 (Man, that's a long site address, but that's what was at the top of the page...)Lots of drop (2.3" F, 2.1" R), decent price ($US143), supposed to be good quality...Anyone tried them?Also, if the drop was a tad TOO much, I suppose you could pop a rubber/plastic shim under each; they sell them from 1/4" up to 2" thick...
NY Pete
Post by NY Pete »
DopeVibeGT
Post by DopeVibeGT »
quote:Coil overs. Coil overs, coil overs! Sorry, just had to put my .02 cents in! With coil overs you can adjust from 0-4 normally and can all but guarantee to get the drop you want!!!Ditto. Cant go wrong with Ground Cotrol coil overs.
inkinAbyssGT
Post by inkinAbyssGT »
I Just changed out my Eibach 1.5 prolines for a set of progress springs because of the 2.2" drop that they provide. However a set of these may be in the future if the progress springs go to S@$T.[link]http://www.mmrusa.com/skunk.htm[/link]
(03 Vibe GT monotone Abyss) Progress 2.2 lowering Springs, Freedom Design tie bar, AEM cold air intake. Borla Catback system, Progress Rear Sway Bar,Pioneer DEH-P8400MP cd/mp3 player. Rockford 1000w amp, dual RF PUNCH 10"'s.
xLR8_Sd
Re: Need some info (inkinAbyssGT)
Post by xLR8_Sd »
been looking at the pro line.but after a friend told me if i lower the car POOOF no warranty. and i paid for an extra 3 years. so i need to find out more info.
NY Pete
Post by NY Pete »
Not true. The only warrantee that'll void is on your shocks/struts and possibly some front end pieces (if they prove the springs or install caused the problem, which is unlikely). I believe something called the Magnussen-Moss Act protects you from the manufacturer voiding your warrantee for aftermarket pieces.
