Drivers Door Switch Plate -- How is it attached?
geezer
Post by geezer »
The Window switches and Door Lock Buttons push down into the door when I push on them.Does anyone know how the panel the switches are mounted into is attached? Is it glued or are there clips holding it. Will I break something else by prying it up or should I remove the entire interior door panel?
XRS 6-speed, Cosmic Blue, 17's, AEM Short Ram, Hidden Hitch
GMJAP
Re: Drivers Door Switch Plate -- How is it attached? (geezer)
Post by GMJAP »
The silver trim and the module underneath that has all the buttons should be attached together.You can remove the silver trim by prying it up on the upper end, then pulling it up and out. I'm not sure if the switch block clips into it or screws into it, but once you get the trim up you should be able to see.
jeffgtx
Re: Drivers Door Switch Plate -- How is it attached? (GMJAP)
Post by jeffgtx »
if memory serves, its a big clip.careful how you remove it, once i did mine, it never clipped back quite the same.
JeffGTX's Shades Of Gray Pontiac Armada:Cool: 2008 Solstice GXP ConvertibleSly: 2009 Solstice GXP CoupeMaverick: 2009 G8 GXP
scherry2
Post by scherry2 »
remove the door panel first!! then look at the back side. never pry up on things unless your sure thats how they come off. just a bit of freindly advice from a former auto repairman
GrayFox
Re: Drivers Door Switch Plate -- How is it attached? (scherry2)
Post by GrayFox »
Definatly take the door panel off first. You should see how everything's attached.
GMJAP
Post by GMJAP »
Quote, originally posted by scherry2 »remove the door panel first!! then look at the back side. never pry up on things unless your sure thats how they come off. just a bit of freindly advice from a former auto repairmanYou don't need to do this. Just pry up on the top of the silver trim. I've removed mine before; this is how it's done. It's described as such in the service manual.See attachment:
scherry2
Post by scherry2 »
Quote, originally posted by GMJAP »I've removed mine before; this is how it's done. It's described as such in the service manual.I wish you would have said that in your first post, I wouldn't have advised this: Quote, originally posted by scherry2 » never pry up on things unless your sure thats how they come off.
damronjr
Post by damronjr »
Quote, originally posted by scherry2 »remove the door panel first!! then look at the back side. never pry up on things unless your sure thats how they come off. just a bit of freindly advice from a former auto repairmanYou're still right, it just happens to be how it comes off in this case!
