I don't think this bolt is supposed to be missing..
June
Post by June »
I was finishing changing the oil on the vibe today and figured I give a look around as I usually do to check for any leaks or obvious things when I see this. Looks like one of the bolts is missing where the exhaust manifold connects to the down pipe. I wasn't the first owner of my vibe, I picked it up used with 11k on it. So I'm thinking it either came from the factory with it missing, vibrated loose or there was a repair previously and they forgot to put this bolt back.Anybody know what size bolt this is? Thanks for the help.
June04 Neptune Vibe, Auto, Monotone, Moons/Tunes, 43k
northvibe
Post by northvibe »
yes say you have a matrix, i just tried to get coolant from a toyota dealer and told them i had the vibe but its the same as a trix xr....now i have the get the exact part # because they are to stupid to know its the same and wont look it up
goodvibe
Post by goodvibe »
Don't be so sure. They're being careful. GM likes to use an extended life coolant that isn't compatable with Toyotas. If you did a complete flush, it wouldn't matter even if they were different.
ricecooker
Post by ricecooker »
just wait and see what problem wil come outnormally noting
June
Post by June »
Thanks for the info. I'll try and stop by the dealer sometimes this week and see if I can pick up the bolt. I'll probably try the GM dealer first since it's right around the corner from work and I can stop by the part dept during my lunch. If no luck there, I'll try the Toyota dealership.
