If you're trying to connect RCA cables to a stereo, there isn't much we can do to help you. RCA is RCA.Are you trying to connect an aftermarket amplifier to the stock radio, and also, the stock speakers?
i already have the amp connected to power, ground, speakers. the amps input is rca. i have some speakers in the trunk. i just need to wire the amp to an imput ( stock HU )
You need one of these to wire into the speaker outputs of the headunit in order to connect the RCAshttp://www.circuitcity.com/ssm...il.do
Quote, originally posted by josholiver1 »How does that connect to the wires in back? It says no cutting or splicing wires...What says no cutting or splicing wires? You'll have to cut or splice something in order to make these devices work.
Tsunami RCA Line Output Converter (FLLOC600) Line output converter: Add an amplifier to your factory sound system with ease by converting your existing speaker wires into RCA outputs, so you can connect an amp to your factory radio without cutting or splicing any wires. ????? Got me...mabie i read it wrong..
Don't know what the description is trying to say, but the Tsunami box is bare wire on one end and RCA jacks on the other.
