it all depends on how you put it in i have 2 12" subs in a good size box and when i need the back to move some stuff all i do is take off the the power and ground wires and put the amp on the box and take it out so it up to you when you put it in on how hard you want to work on taking it out hope this helps
If it's a standard tube, depending on how you connect it, loosen two straps, unplug the main harness, and unplug the RCAs.If you don't have an aftermarket radio and aren't using RCAs, then you just have to unplug maybe one or two harnesses (depending on the model you get and how it's connected to power.)So...pretty easy.
Very simple and pretty much what Jahntassa said. I have an amplified Bazooka with the stock head unit. All you have to do is unplug the power connector and the one harness with inputs. Then loosen the straps and it's free. I've done this several times when I need the little extra cargo space. That's why I like my Bazooka so much, takes little space, sounds great, and removes easily.
Justin 2003 Vibe GT - Mille Miglia Evo5 18x8 Wheels (now stock)- Magnaflow Cat-Back Exhaust (now stock)- Tein S-Tech Springs (now stock)- Injen CAI - Red Painted Calipers - Hella Supertone Horns - Polk Speakers - Bazooka RS8A-HP Sub - Kenwood Headunit - Still love my Vibe, but I've just turned it back into a basic daily driver.
