Seat Belt beeping noise
ViberSteve
Post by ViberSteve »
who knows how to deactivate the beeping noise if i didnt have my seat belt on?Is it in the manual somewhere?Or is it done at the dealer?Sorry, just bought my Vibe yesterday!
Mrizzle05
Re: Seat Belt beeping noise (ViberSteve)
Post by Mrizzle05 »
Hey welcome to the club!!!heres the link to the thread on how to disable it!good luck!
Mrizzle05
Re: Seat Belt beeping noise (Mrizzle05)
Post by Mrizzle05 »
sorry forgot to put the link in... Here you go,http://forums.genvibe.com/zerothread?id=18678
ViberSteve
thank you. i just figured out how to search old threads. hehe sorry but thanks!
Mrizzle05
Post by Mrizzle05 »
Hey thats what we are here for!hope you like it here and find what you need!
Katscan
Post by Katscan »
Why not just wear your seatbelt? It saves lives you know.
Atomb
Post by Atomb »
cut the seatbelt and take the metal piece and stick it inot the buckle...that way your seatbelt is techincially 'always on'.if you want to disregard the obvious safety reasons behind a seatbelt, then you wouldn't mind cutting the belt and making it useless.
BlueCrush
Re: Seat Belt beeping noise (Katscan)
Post by BlueCrush »
Quote, originally posted by Katscan »Why not just wear your seatbelt? It saves lives you know.I have a briefcase that regularly sets off the seatbelt alarm due to the weight. That is why I have mine off. Thank god!Also, If you disconnect your battery for any reason after you disable the seatbelt beep you will have to do it again as it will reset itself to go on again.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
Re: (Atomb)
Quote, originally posted by Atomb »cut the seatbelt and take the metal piece and stick it inot the buckle...that way your seatbelt is techincially 'always on'.if you want to disregard the obvious safety reasons behind a seatbelt, then you wouldn't mind cutting the belt and making it useless.I always wear mine, but on the 03, the passenger belt warning is a flashing light, which I disconnected for pretty much the same reason as BlueCrush.People do a lot of dangerous things in their cars, street racing, no seat belts, tossing cigarette butts out the window, tailgating, etc.
BlueCrush
Re: Seat Belt beeping noise (silverawd26)
Post by BlueCrush »
Quote, originally posted by silverawd26 »That is a catch 22, if something happens and your air bag goes off I am not sure how it will effect it. Just a heads up on that one, maybe someone here knows? All it does is turn off the beep. The airbag feature still seems to function normally. That's why it says "b-on" and "b-off" on the odometer.The airbag indicator on the dash still says "off" when no one is in the passenger's seat and "on" when there is someone sitting there.The only reason the airbag should go off is if you are in an accident.If it goes off for any other reason, your pretty much screwed anyways.
My Fleet:
