HELP! I can't find the fuse panel!
Marco922
Post by Marco922 »
I have an '03 Vibe and I can't find the fuse panel. I have found the one under the hood, but isn't there one inside the car?
Waxler6942
Post by Waxler6942 »
Above the drivers feet there is a fise panel, It has a cover on it you have to pull the cover off. If you kinda lay on you back and look up it is there
2003 MonoTone Base / MT PackagePioneer AVIC-N1 with Sirius TunerPolk db6500 ( front ) Polk MMC650 ( rear )Directed 750d Amp ( underback seat ) pushing Polk Momo 12" Focal F10 18Rain Guards 2% Tint in Rear with Drips on FrontPainted Side MirrorsCustom Hood
damronjr
Re: (Waxler6942)
Post by damronjr »
Yep, under the dash on the drivers side. Should be right above your left knee.
Re: HELP! I can't find the fuse panel! (Marco922)
it's on the driver's side, up under the dash. You have to come from the floor up to get to it, but, if you pulled out the storage compartment on the left side of the dash (the one under the dimmer switch and mirror controls), you could see the top of it. unfortunately, the fuses are on the bottom of it, it's inconvenient. Good luck, the location of it is less than idealedit2 I got beat on this one
binary
Post by binary »
yep, it's a behotch to get at... combine the fact that it has a cover, uses mini-fuses, and I have less than small fingers all made swapping out a fuse a situation that was rated R for mature audiences only.
Marco922
Post by Marco922 »
I found it....thanks!
