water pump leaking
hman33
water pump leaking
Post by hman33 »
well, i just crawled out from under my vibe to see what was leaking. i thought it might be the tranny since i just recently had the oil changed at the Pontiac dealer. i thought maybe they loosened the wrong bolt. to my suprise i found a drop coming out of the water pump below the pulley. the car is a 2003 gt with 15k miles on it. just woundering if anyone else has had this problem?
'03 monotone lava gtpower package, moons and tunes,k & n short ram,grafxwerx overlays and inlay
Emerica13
Re: water pump leaking (hman33)
Post by Emerica13 »
Wow! 03 gt with only 15k? ive got an 03 gt with about 45k already, anyway, ive never had any problem with my water pump, sorry i cant give any more info, good luck
2003 Shadow Vibe GT
dog paw
Re: water pump leaking (Emerica13)
Post by dog paw »
Better check it closely. Maybe they had the radiator cap off and made a mess. I have never seen a water pump failure on a Vibe come through our service dept yetOh 53k on my 04
A running apology for misspells and general butchering of the Kings English
hman33
Post by hman33 »
yeah, i'm kind of lucky. i get to drive my work truck home and not use my car to drive back and forth. i checked around the engine compartment and didn't see any fluid orther than the drips form the water pump.
If you are still under warranty (<3 years) take it back to the dealer.
hman33
Re: water pump leaking (joatmon)
Post by hman33 »
most definitely,i think the warranty runs out in june.have to make the best use of that warranty.
Casper60
Post by Casper60 »
I have a 07 Vibe with about 20,000 km. I had a strong smell of antifreeze. Took it to one dealership , then went to a different dealership. They pressure tested the system, put dye in it and I drove it around for a couple thousand more km.. The water pump was leaking and had to be replace. The first dealership had a closed mind. NOTHING goes wrong with a vibe. Guess what. The water pump needed replacing.
skylinedrifter
Post by skylinedrifter »
Lucky you... this might be an opportunity to find and install an electric water pump and save a few HP. ;-)
JohnC
Post by JohnC »
This may help...I had the same problem.http://forums.genvibe.com/zero...85769
