Tire Inflation
fsfrick
Tire Inflation
Post by fsfrick »
What is the proper tire inflation (PSI) for a 2004 Vibe? Where is the tire inflation sticker, or where is the info in the user's manual?FSF
Raven
Re: Tire Inflation (fsfrick)
Post by Raven »
32 psi I think it's on the sticker in the glove box.
fsfrick
Re: Tire Inflation (Sunny)
Post by fsfrick »
Sunny,Thanks a lot!FSF
binary
Post by binary »
Most vehicles have it on the driver's side door. I think many manufactures standardized (if you can call it that) after the whole firestone/ford disaster.Regardless, my '05 has it on the door.
Raven
Re: (binary)
Post by Raven »
Quote, originally posted by binary »Regardless, my '05 has it on the door.My '06 has it on the door also but my '04 had it in the glove box and fsfrick has an '04.
joholste
Post by joholste »
check your actual tires, it should tell you the max PSI, if you're going for max MPGs run about 2PSI underneath max, if you want more comfort then i would suggest 32-36
2003 Chevy Silverado Ext. Cab, Z71Formerly2003 Base Vibe (Frosty)
mcgusto82
Re: (joholste)
Post by mcgusto82 »
36 mpg improve fuel economy. but the ride is a little stiff on low profiles. it feels fine on stock tires.
GMJAP
Re: (joholste)
Post by GMJAP »
Quote, originally posted by joholste »check your actual tires, it should tell you the max PSI, if you're going for max MPGs run about 2PSI underneath max, if you want more comfort then i would suggest 32-36In general, though, you should set the tire pressure to the vehicle maker's recommendation, not the tire's.
48-remi
Post by 48-remi »
I run my tires at 32 psi front and 30 psi rear. My wife's Maxima is set up the same (33/30) . The weight distribution on the Vibe is 60/40 front and rear so the 30 psi on the rear makes the ride less jumpy.
binary
Re: (Sunny)
Post by binary »
Quote, originally posted by Sunny »My '06 has it on the door also but my '04 had it in the glove box and fsfrick has an '04.Ah - good catch. Thanks!
