Fueling Problems--Gas Pumps Clicking Off Everywhere and all the time
jbras
Post by jbras »
Hello,Our Vibe is just about impossible to fuel. Regardless of the gas station and position of the nozzle, the nozzle will click off in seconds, always.Any thoughts as to how to explain this to the mechanic or as to what is going wrong are very much appreciated as it seems very strange to us.Thanks,Jim and Lori B.jbras@bulloch.com
Raven
Re: Fueling Problems--Gas Pumps Clicking Off Everywhere and all the time (jbras)
Post by Raven »
Have you tried pulling the nozzle out an inch or two when filling? I usually don't hold the nozzle full on, I fill at about 3/4 pressure and find it clicks off very rarely.Oh yes, I almost forgot...Welcome to Genvibe!
Baltovibe
Post by Baltovibe »
I had the same situation last night. It was so cold, that the rubber boot that surrounds the nozzle (I guess to catch the gas fumes) was stiff and would not let me fully insert the nozzle into the filler tube. When I tried to pump the gas, it would keep shutting off.My particular solution was to physically force the nozzle deep into the filler tube, and pump more slowly. I figured that when the nozzle is partially inserted, gas must back up in the filler tube and trip the auto-shutoff.
Mavrik
Re: Fueling Problems--Gas Pumps Clicking Off Everywhere and all the time (Baltovibe)
Post by Mavrik »
there is a possible filler neck issue from the cap to the neck. Saw the same situation with a Sunfire a couple years back... only time I ever came across it. Now if your having the same problem with different pumps... may be there is a restriction in the tube.
in http://forums.genvibe.com/zerothread?id=5204 wildvibe had this problem, but he never reported back if it got fixed and hasn't posted in a year and a half, so no closeout/resolution, but that thread does list some possible causes.
Baltovibe
Re: Fueling Problems--Gas Pumps Clicking Off Everywhere and all the time (joatmon)
Post by Baltovibe »
Quote, originally posted by joatmon »wildvibe had this problem, but he never reported back if it got fixed and hasn't posted in a year and a half, so no closeout/resolution, but that thread does list some possible causes.Wildvibe did report back and the problem was resolved by replacing the filler tube.http://forums.genvibe.com/zerothread?id=5686
Mavrik
Post by Mavrik »
wow I was right on the money. Filler tube. Kinda miss working for GM... I don't get the latest info and know how anymore.
djb383
Post by djb383 »
Like Sunny said, don't stick the nozzle all the way in.
Atomb
Post by Atomb »
Quote, originally posted by Baltovibe » It was so cold, that the rubber boot that surrounds the nozzle (I guess to catch the gas fumes) ...that rubber boot is to stop back splash if you accidently fill too full....i remember when they started using them there was a newspaper article discussing the number of people that got gas all over their clothes when the accidentally over filled (ignoring the auto shut off described in this thread).
Raven
Re: Fueling Problems--Gas Pumps Clicking Off Everywhere and all the time (Atomb)
Post by Raven »
The rubber boot is actually to reduce the amount of unburnt hydrocarbons released into the atmosphere. Stopping the backsplash is a bonus though and does reduce emissions as well.
jake75
Re: Fueling Problems--Gas Pumps Clicking Off Everywhere and all the time (djb383)
Post by jake75 »
Quote, originally posted by djb383 »Like Sunny said, don't stick the nozzle all the way in. If it's a short nozzle that isn't an option.
djb383
Re: Fueling Problems--Gas Pumps Clicking Off Everywhere and all the time (jake75)
Post by djb383 »
If it's a short nozzle, it will probably flow just fine because a short nozzle is like a long nozzle that is not fully inserted.
jbras
Post by jbras »
Wow, Thanks for the great advice. I followed the link and printed it out. Turns out, the first thing in the manual "The fill limiter vent valve (FLVV) is stuck closed" is the problem. They ordered the part and it will be in tomorrow. He told me to bring the car in tomorrow or next week and he'd have the same mechanic replace the part right away.Our dealer is great. From checking in to checking out was less than an hour and they changed the oil, too. They always do a good job and are really courteous about wait times and/or supplying courtesy transportation if needed. He said that bringing in some possible info about the problem really saved the mechanic some time and thanked me for it.Thanks again,Jim
Atomb
Post by Atomb »
another job well done by "GENVIBE TEAM!" yay!transform...and roll out!
Mavrik
Re: (Atomb)
Post by Mavrik »
Maximize! or something...this thread is getting out of hand lol.
binary
Post by binary »
Quote, originally posted by Atomb »that rubber boot is to stop back splash if you accidently fill too full....i remember when they started using them there was a newspaper article discussing the number of people that got gas all over their clothes when the accidentally over filled (ignoring the auto shut off described in this thread).Depends on where you live. Some stations are required to recover fuel vapors at the filler neck by using a boot that seals off the filler neck from the atmosphere and vacuums the vapor back to a recovery system.Others just have a backsplash guard to keep fuel from splashing back on you after you've attempted to fill your tank three times after it clicked off...
