Help with in-car heater
huy397
Post by huy397 »
Hello... I am thinking of buying a in-car heater for my Vibe since it gets very cold in the morning and I park outside all the time. My questions are... 1. I don't suppose I can use the heating fans I use at home because the plug-in doesn't have enough power for it ? I should be looking for something with 12V plug? 2. Where can I find them? and how much do they normally cost? Thank you
Car: 2003 Two tone Base Frosty Vibe, Automatic, Safety & Security Package, Power Package and 16" alloys with 16" Blizzaks for winterNavigation: HP iPAQ 2210 + LeadTek 9537 BT GPS + iGuidance V2.1.1 + German-D mount.http://www.howardforums.comYour Mobile Phone Community & Resource
Re: Help with in-car heater (huy397)
You can find small-ish ones for a small area that just plug into the lighter socket...For instance: http://www.jcwhitney.com/autop...eaterI don't know how well something that small would work, but if you just need warmth to blow on or around you, maybe that would help and maybe will get warmth to you a bit before the Vibe's heater can.. I have found those from time to time at places like Wal*Mart for pretty cheap, so it shouldn't be too hard to find one.. But something like that will never be as good as one of those small 110V space heaters though...
zionzr2
Post by zionzr2 »
you will also have to re-wire (if you have not done so already) the sockets as they are only active if the car is on.And you can kiss your battery good bye too!
mikey00
Post by mikey00 »
You need a remote starter, so you can start the car and warm it up before leaving the house.
eSSjAy
Post by eSSjAy »
Or a more expensive solution is an engine block heater like us Canucks up here do. Just plug 'er in before you go to bed and she's pretty warm by the time I get to the end of my street.
Altus
Re: (eSSjAy)
Post by Altus »
Not that I've used the block heater yet..... but if you put it on a timer, and have it switch on 2 hours before you need the car, its still nice and warm, and saves you some 6 hours or more of electricity.
Shadow-Vibe
Re: (Altus)
Post by Shadow-Vibe »
Call me stupid, but if you have the block heater will this make your heater inside the car work faster?
binary
Re: (Shadow-Vibe)
Post by binary »
Quote, originally posted by Shadow-Vibe »Call me stupid, but if you have the block heater will this make your heater inside the car work faster? No, I won't call you stupid.The block heater keeps the coolant inside the block warmer, providing freeze protection and sometimes (depending on the ambient temp) can increase the overall coolant temp.This is the same coolant that circulates through your heater core that warms your interior.On wicked cold days, you won't get much return on your energy costs. Because the engine is really good at sheding heat... the block heater's primary job is to keep the engine coolant from freezing.
millster
Re: (Altus)
Post by millster »
Quote, originally posted by Altus »Not that I've used the block heater yet..... but if you put it on a timer, and have it switch on 2 hours before you need the car, its still nice and warm, and saves you some 6 hours or more of electricity.My only concern with doing that would be current draw. Remember that a resistive heater pulls quite a bit of current. Please, if you're going to use a timer make sure it's rated to support that kind of load! Don't burn your house down just to save a few dollars!
-Millster-
2006 Toyota Matrix XR
1995 Saab 9000CSE 2.3T
