Kill Switch?
June
Kill Switch?
Post by June »
My vibe came with the power package but minus the alarm. I don't have the cash for an aftermarket alarm now so I'd like to install a kill swith for those time when I park in questionable areas. I'm thinking a fuel pump kill switch would probably be easy to set up. What do you think? Thanks for the help.June
June04 Neptune Vibe, Auto, Monotone, Moons/Tunes, 43k
Jahntassa
Post by Jahntassa »
It'd be pretty easy, you just need to find the wires that lead to the fuel pump, and i'd get a relay to handle it.. I can explain the setup if someone with a service manual can ID the wires..
Mavrik
Re: (Jahntassa)
Post by Mavrik »
Well simply look in your trunk, the access to the fuel pump is under the floor, so are the wires.
JohnC
Re: (Mavrik)
Post by JohnC »
Quote, originally posted by Mavrik »Well simply look in your trunk, the access to the fuel pump is under the floor, so are the wires.Or there should be a fuel pump relay under the hood.
mcgusto82
Re: (JohnC)
Post by mcgusto82 »
a starter kill relay might be easier to install since the wires are basically in plain sight.
Baltovibe
Re: Kill Switch? (Mavrik)
Post by Baltovibe »
Quote, originally posted by Mavrik »Well simply look in your trunk, the access to the fuel pump is under the floor, so are the wires.I thought the fuel pump was under the rear seat?http://forums.genvibe.com/zerothread?id=19724
