XM on the factory radio - Info Sheet
ZubenElGenubi
Post by ZubenElGenubi »
Just thought I'd post this for future reference. It's a PDF file on how to use XM on the factory radio (when equipped). I found it at XM's website (you can generate one for any vehicle where XM is available as an option).
Attached files XM-Vibe.pdf (136.5 KB)
mcgusto82
Re: XM on the factory radio - Info Sheet (ZubenElGenubi)
Post by mcgusto82 »
So is the XM tuner a seperate unit on the 06's or is it built in the HU.I don't know if you guys know, but the 04 without cd changer has a 12 pin harness. The one where the changer goes to. This harness goes all the way to the rear pass side pocket. Is this where the XM tuner is located on the later models?
