Hi all. I was recently reding on
http://www.suzukiaerioforum.com and found this topic to be interesting. The post was on page 2, near the bottom by Mr.Bill (no, not MadBill). This is the link to the page
http://suzukiaerioforum.com/ae...rt=20This is what he said:"I'm tellin' you guys it's your tire pressure. When I went on a trip to LA I got 372 miles on one tank of fuel. (AWD even) Filled up when I got there, and the car only took 10.4 gallons. But before I left I filled all my tires to 40 psi. (the tires say max is 44) Car rode fine, the steering was more responsive and the car manuvered crisply. I wouldn't be at all suprised if when the EPA tests cars for fuel mileage, they are inflating the tires to their maximum recommend pressures and ignoring the sticker in the door jamb. Besides, aren't those only broad overall suggestions? It's not like Suzuki manufacturers Yokahama tires, and knows what they can take or are rated for. It's like a "legal" sticker. Because you may buy tires that aren't rated as high a pressure as the OEM tires. So they just use the 32 psi as a general rule. If you guys haven't noticed, but when our tires are at 32 psi, the look flat and the sidewall rubs the pavement. I'm a firm beliver that the day of 32 psi is fading along with leaded gasoline. Today's tires are computer generated, they use a more sophistocated wrapping processs and hi-tech materials. They are designed and engineered with newer rubber/composite compounds to give longer wearablilty as well as outstanding over all traction in multiple conditions. It was not long ago when it was unheard of to have a tire that could be used safely in the rain, and still stick to the dry pavement. I'm not saying that the Geolanders are at the forefront of tire technology, it's just that every "NEW" tire that I've bought in the last few years has a way higher maximum rating than 32 psi. Because on tires of old, they say do not exceed 32 psi. So I'm not dreaming this stuff up. I had purchased some cheapy Korean tires (Nankangs) for my other car, they were a 40 series, and even on those the recommended tire pressure was 40 psi. It's like no one wants to make a commitment one way or the other. The tire companys say, "Inflate your tires to the auto manufacturer's recmoomended pressures." and the Auto manufacturers are saying just the opposite. I'm sure it's all legal crap. Because no one wants to be at fault when it comes to an accident when a tire fails. Remember Firestone? Firestone said that the SUV's were prone to flipping over and showing sings that they were not tire friendly. While Ford on the other hand said that their SUV's wouldn't have flipped over if Firestone's tires hadn't blown. Back and forth, back and forth. I'm keeping my tires at 40 psi, and I will continue to reap the benefits of getting a consistant average of 28 mpg with my AWD Automatic!Last edited by Mr.Bill on Fri Mar 28, 2003 8:56 am, edited 1 time in total"I then did a search on genvibe.com to see what people here have to say, and pulled up this thread.
http://forums.genvibe.com/zerothread?id=2032In here, novaresource says that raising pressure reduces the contact patch which gives less rolling resistance which equals better fuel economy and that lowering pressure gives more rolling resistance (which says to me it gives better traction) as long as the pressure stays above the tire "cupping" level.In the next post below, MadBill goes on to say that when finding ideal pressure for best cornering, slowly add pressure to the tires that slip until optimal is found. That tells me that adding pressure gives more rolling resistance which is better traction.So, which is it? If I am reading MadBill right, higher pressure = better handling? If I am reading NovaResource right, I see the opposite. Both seem to agree on less rolling resistance equals better fueleconomy. Back to the aerio page, this Mr.Bill uses 40 psi in his tires which can handle a max of 44 and the aerio says to use 32. Both the 44 and the 32 numbers are the same as the vibe. This guy is claiming about 3-4 MPG better by using 40 psi instead of the OEM spec 32. Can that be done in the vibe safely?
