Thinking of buying a Vibe
AndyLT1
Post by AndyLT1 »
I'm new here and thinking of buying an '06 Vibe. I'm a Pontiac guy so the Matrix is not an option. My issue is the stock head unit. My wife uses cassette's and needs a cassette player. I use CD's. I want a combo head unit and I don't like how aftermarket looks. I know a Matrix combo head unit can bolt right in, but I want the orange lighting like the stock Pontiac would have. Are there any options for this? Thanks in advance for any info that can help me out.Thanks,Andy
'06 Abyss monotone AWD Vibe'00 Black S-10 ZR2 pick-up'02 Quicksilver Corvette Z06
tnpartsguy
Re: Thinking of buying a Vibe (AndyLT1)
Post by tnpartsguy »
there is a combo AM/FM CD-Cassette unit on Ebay right now.*I am NOT the seller*.
Toolman
Re: Thinking of buying a Vibe (tnpartsguy)
Post by Toolman »
You may want to check the Wiring harness on that, I dont think it is the same for the Matrix and Vibe. It would most likely be a custom wiring job that would need the Toyota wiring harness.
http:/theeulogy.wirefire.com2003 Neptune Blue Moon and Tunes4 Speed AutoBluetooth Install(Wifes)2004 Torrid Red GTO Tinted WindowsBluetooth Install0-60mph in 5.2 seconds0-130mph in 22.5 seconds(Mine)
damronjr
Re: Thinking of buying a Vibe (Toolman)
Post by damronjr »
Quote, originally posted by Toolman »You may want to check the Wiring harness on that, I dont think it is the same for the Matrix and Vibe. It would most likely be a custom wiring job that would need the Toyota wiring harness.If they are both double DIN, which I assume they should be, then you shouldn't have any problems. I'm not positive on this, just making an educated guess!
Toolman
Re: Thinking of buying a Vibe (damronjr)
Post by Toolman »
Further info on the matrix radio http://forums.genvibe.com/zerothread?id=19401
tampa8
Post by tampa8 »
I have a 2004 vibe and bought the matrix radio with the cassette player and it was plug and play - no problem. The screen on it is the same (red) as the one in the Vibe. HOWEVER - the 2004 model did not offer ON STAR, and I believe now that the Vibe does have ON STAR the radio is not compatible because of the electronics needed to work with ON STAR. I am not an expert, so definately check with someone who knows for sure before you buy a Matrix radio.
Toolman
Re: Thinking of buying a Vibe (tampa8)
Post by Toolman »
My bad, pre 05 they were the same. Should work then.
I have a CD/tape unit from a Matrix in my Vibe, both are 2003. In 2005 Toyota went with their own head units, so the connections/look are different. I would think that a CD/tape from a 2003 or 2004 matrix would fit a 2006 Vibe no propblem. If would not support XM or OnStar, as has been said.Today there are two Matrix CD/tape units on ebay.The first one, http://cgi.ebay.com/ebaymotors...ZWDVW is wrong, too new and won't just plug in, and may possibly not have the red look you want. looking at the picture I am not sure that one is really a tape deck, althogh the listing claims it is.The second one, http://cgi.ebay.com/ebaymotors...ZWDVW is what you want, one that looks exactly like the stock 1CD Vibe head unit, except it also has a slot for a cassette.On my Vibe, it was just unscrew, unplug the old radio, plug and screw in the new one, no wiring changes at all. I have also done this in a 2005 Vibe, no problems. 2006? I would think that it should be the sameI won't say if the price on that second ebay unit is good or not, I've seen them go for more or less than that one, but I suppose that since Toyota isn't putting them in Matrixes anymore, the supply is probably limited. They do come up from time to time though.
jake75
Re: Thinking of buying a Vibe (joatmon)
Post by jake75 »
Wonder if anyone makes a cassette to CD recorder? That might be the better resolution toi wife has cassettes, I have CD's problem.
northvibe
Post by northvibe »
cassette to cd, would usually have to be done on a pc. where you input the cassette and record to say mp3 files and then burn those to cd's with ur fav. cd burning software ie. nero burning rom. if you want to make it easy just go to a computer store (compusa, best buy etc.) they have hardware/software like pinnacle stuff that can make it easy for ya.
AndyLT1
Post by AndyLT1 »
Thanks for all the info. I could copy everything to CD for her, but that would involve my having the initiative. I'll have to check out those used Matrix head units. I wouldn't get Onstar or XM anyway, so that seems like a good idea. Now to just get to the dealership so my wife can test drive it. Thanks again,Andy
GMJAP
Re: (AndyLT1)
Post by GMJAP »
Quote, originally posted by AndyLT1 »Thanks for all the info. I could copy everything to CD for her, but that would involve my having the initiative. I'll have to check out those used Matrix head units. I wouldn't get Onstar or XM anyway, so that seems like a good idea. Now to just get to the dealership so my wife can test drive it. Thanks again,AndyPS- you could probably get decent price on your 2006 stock 1CD (which should pay for the CD/Cassette combo) as the 2006 1CD has MP3 capability. Probably some members here who would find that very attractive.
Baltovibe
Re: Thinking of buying a Vibe (jake75)
Post by Baltovibe »
Quote, originally posted by jake75 »Wonder if anyone makes a cassette to CD recorder? That might be the better resolution toi wife has cassettes, I have CD's problem. There is a product available that might do what you want. It is called the Plus Deck 2 and fits into a 5-1/4" drive slot in the PC. More details at http://www.a1-electronics.net/...shtml
mcgusto82
Re: Thinking of buying a Vibe (Baltovibe)
Post by mcgusto82 »
wow. i haveen't heard of anyone using tapes in years.
mcgusto82
Re: Thinking of buying a Vibe (mcgusto82)
Post by mcgusto82 »
by the way. welcome abord. i'm in yonkers.
pianomansam
Post by pianomansam »
Quote, originally posted by mcgusto82 »by the way. welcome abord. i'm in yonkers. Yonkers is a bit far from Rochester I just moved to central Ohio from Batavia, though, so that would be pretty close to the guy
2003 Two-tone White Vibe GT 6-speedSeveral other cars2005 Two-tone Neptune Vibe Auto (sold)
AndyLT1
Post by AndyLT1 »
That cassette thing for the computer is pretty coool.
tnpartsguy
BTW Andy, if you really want to see if you like the Vibe, if your dealer won't do an 24 hr test drive, you can always rent one from Enterprise for a day or 2 to make sure it suits you both.
BOZACK
Re: (tnpartsguy)
Post by BOZACK »
Are there any new cars that offer cassete players today? With everything going to MP3's, cassetes are soon to go the wat of 8-tracks.
Monotone Neptune, pow pac, 17" stock rims, K&N air filter, bumper guard, custom pedels, brake light cover, billet oil cap
binary
Re: Tapes
Post by binary »
Quote, originally posted by BOZACK »Are there any new cars that offer cassete players today? With everything going to MP3's, cassetes are soon to go the wat of 8-tracks.Some low end Kia's (no, I'm not trying to be redundant... ), Hundais still have am/fm/tape decks on their base configs... Although you'll be hard pressed to find one on a lot with it.
AndyLT1
Post by AndyLT1 »
My dealer will give me a 24 hour test drive when I want one. I'm waiting for an AWD to come in. Since we'll be replacing my wife's Cherokee with the Vibe I want the AWD.
