What engine do I have?
russd10089
Post by russd10089 »
I'm a new Vibe owner, and i've been reading over these forums for about a week now. And i think i've seen at least 3 different engine #'s. And have no clue which one i have.I've got a base 05' Vibe.Also, it'd possibly be helpful to have a sticky stating which Vibe's have which engine, for new people like me.Thanks.
05' Vibe, Salsa
jwalcik
Re: What engine do I have? (russd10089)
Post by jwalcik »
as far as i know, there are only two engines in any vibe out there, the 1ZZ found in the base, and the 2ZZ found in the GT. over the years the 2ZZ has been tuned down quite a bit, but as far as i know, the 1ZZ is the same as it's always been (except that the '05's have drive-by-wire).what other engine number have you seen? if you're referring to horsepower ratings, the 2ZZ engine seems to get tuned down a little more each year in regards to peak horsepower (from 180 in the '03's to 170 in the '05's).
2005 vibe gt
kostby
Post by kostby »
The base and AWD have the same 1ZZ engine. The horsepower is slightly lower( - 7 hp? ) for the AWD because of a more restrictive exhaust system. The 1ZZ was rated at 130 hp on '03 and '04 in the base, and 123 in the AWD. Not sure about 05/06 ratings.The GT has the 2ZZ engine. I think the 2006 rating is now 164 horsepower, down from 180 in '03 and 173 in '04
http://forums.genvibe.com/zerothread?id=824 indicates what each digit of the vehicle identification number means. Quote »The 8th digit is the Engine type: 8 = 1ZZ engine; L = 2ZZ GT engine
russd10089
Re: What engine do I have? (joatmon)
Thank you everyone.I thought i had seen a 1z, 1zz, and 2zz engine. If i did, they probably meant the 1zz.
05' Vibe, Salsa
As was said, there are only 2 engines out there.Look at the side of the engine block as well. Mine had a sticker that said something like 1ZZ-FE somewhere on it.
Re: (ragingfish)
Yeah, find the drive belt and look at the block on that area... Big ol' sticker.
