What oil filter do you use?
jasonvibe
Post by jasonvibe »
I am about to do my first oil change. I have always used Purolator(96% multipass effic) or WalMart(Champion) filters (99% multipass effic). I will be using Mobil 1 5w30 oil. When compared to others, I did notice the Purolator had smaller input holes on the base. What filters do the folks here use? thanks in advance...
joholste
Post by joholste »
i use the K&N filters outstanding filters
2003 Chevy Silverado Ext. Cab, Z71Formerly2003 Base Vibe (Frosty)
Pyro-Andrew
Re: What oil filter do you use? (jasonvibe)
Post by Pyro-Andrew »
i use the Purolator one....
Have: 2006 Pontiac Torrent. Perferred Package. Sun & Sounds Package. Blue Streak Color. Sirius Radio.
Raven
Re: What oil filter do you use? (Pyro-Andrew)
Post by Raven »
I just bought a Walmart filter for $2.00 and a jug of Mobil 1 for $20.00 in Ogdensburg, NY. This equals $26.00 Can. The same two items would have cost me $45.00 Can. here at Canadian Tire.
Jahntassa
Post by Jahntassa »
I use K&N, with the Mobil 7500 mile half-synthetic oil.
Altus
Re: (Jahntassa)
Post by Altus »
My Wal-Mart here has Mobil1 4.4L jugs for $24.78 canadian -- I'm planning on stocking up a few :->I use the Toyota Denso filters - cheap, only $6.95 - and they filter as well as Mobil1 or Purolators. If you're using the Purolator - go for the Gold ones - they flow better with the same filtration or better.
AC Delco.
northvibe
Post by northvibe »
on my first oil change i used mobil 1 oil and a Purolator filter, both from fleet farm.
jasonvibe
Post by jasonvibe »
Altus said, the Pure-Gold filters? I don't think I have seen them? I used the Premium Plus in the past. I bought the "pure-one" for another car. But it filtered too well. The oil pressure on my gauge read significantly lower at start up. So PureOne I stay away from. Atlus, Maybe that's the gold? Thanks guys...
ZubenElGenubi
Re: (jasonvibe)
Post by ZubenElGenubi »
I use the Fram X2 Extended Guard filters (XG4967) with Mobil 1 5W-30 as well.
Lancer
Post by Lancer »
K&N oil filter and AmsOil 10k mile oil. Heard a lot of bad things of Fram oil filters.
jasonvibe
Post by jasonvibe »
I have also heard negatives about fram. Plus have notice strange things with some of the vehicles I had, when frams were install. I won't go into that. Their filter media is good but the amount of it is not as much as others. Also their bypass valves are not known for quality...nuff said.
JustinVGT
Post by JustinVGT »
I use the Purolator One filter. After reading a lot of info on filters, the conclusion was that the Purolator One filters are excellent and it only cost around $2.50 at Advance Auto Parts.
Justin 2003 Vibe GT - Mille Miglia Evo5 18x8 Wheels (now stock)- Magnaflow Cat-Back Exhaust (now stock)- Tein S-Tech Springs (now stock)- Injen CAI - Red Painted Calipers - Hella Supertone Horns - Polk Speakers - Bazooka RS8A-HP Sub - Kenwood Headunit - Still love my Vibe, but I've just turned it back into a basic daily driver.
djb383
Post by djb383 »
AC Delco Duragard
jasonvibe
Post by jasonvibe »
Pontiac is GM's original sports car division. Wish these Vibes had complete(volt & oil pr.) gauges. On my last car... That's how I knew I had a bad PureOne filter. Also other problems showed on the oil gauge before it was terminal.
ToolGuy
Post by ToolGuy »
Always use AC for my GM vehicles and they are proven very good filters.With any car under warratny I always use the manf type filter i.e. AC or Mopar. Besides what I mentioned about AC filters I use the original equipment type just in case the engine has issues. The dealer can never blame my filter for some reason and decline a repair. Even in a lease vehicle.
jasonvibe
Post by jasonvibe »
It is against Federal law to require a vehicle owner to use ONLY OEM parts which require routine replacement. Any dealer that refuses to honor a warranty repair because of non-use of an OEM RRP (routine replacement part) can be closed down. AC Delco buys their filters from someone else anyway.
ToolGuy
Post by ToolGuy »
Still under warranty, it is a chance I rather not take since I change my oil on my own... Maybe it is easier to do this because I change it on my own I can by whatever filter I need rather than go to an aftermarket place. AC makes their own filters to the best of my knowledge but if they do buy them from someone else it does not matter because they are installed on engines from the plant and designed for the engine.
Mr. Poopypants
Post by Mr. Poopypants »
I always use the Purolator PureOne.
nismo
Post by nismo »
I use the K&N oil filter, Inder
scott_h
Post by scott_h »
I used a Mobil1 the first change and Wix the last one. I think I'm going to stick with Wix - I've read good things about them, and they're half the price of Mobil1 and K&N.A lot depends what is readily available to you... I can buy Wix at an Ace Hardware about 3 miles from my house, but have to drive over 30 miles to get Mobil1/K&N (which makes the cost go up even more!).
Scott
redvibe05
Post by redvibe05 »
Mobile 1 oil and AC Delco filter !
Man of Steel
Post by Man of Steel »
A lot of guys over at BOB IS THE OIL GUY website use the white Purolator One's, which is what I use now. For the money, they claim they're about the best filter you can buy. Pep Boy's often has them on sale. Also, the Pep Boys PRO LINE filers and Auto Zone's TOTAL GRIP filters are made by Purolator and they're supposed to be good filters. Both are about $2.50 regular price. I used to use FRAM's but hearing lots of negative stuff about them.
05 AWD.
pdworak
Re: What oil filter do you use? (Man of Steel)
Post by pdworak »
Despite all the bad rap about Fram filters on the net, I have used Frams for all my vehicles (including motorcycles) for as long as I can remember (20+ years). This is mainly due to thier low cost and wide availablity, not that I have some preference. I have personally never had a problem with the filters exploding or other such reported issues. These types of reports usually go like this: "I have a freind who has a friend who heard about some guy racing his highly modified car when the Fram filter on his car exploded and caused him to crash". Maybe these are legit reports, maybe not. I have also had reasons to tear apart the engines on several cars that I ran Frams on. These were unrelated to oil or oil filters and included blown head gaskets and the like. I always found the inside of the engine extremely clean and virtually no wear on the cylinder bores or crank journals or cam journals. I typically blend my own oil using 50% synthetic and 50% regular. I use the same brand and viscosity for both. I change oil every 3 to 4K miles. Occasionally I put in some Risollene or other oil detergent. This works for me, but I certainly don't have any scientic proof one way or the other. I suspect that under normal use, even the worst, cheapest oil filter will be perfectly fine. Here are some links to a couple of oil filter studies, one relates to motorcycle filters, but is informative anyway.http://minimopar.net/oilfilterstudy.htm ... hanks,Pete
Toolman
Re: What oil filter do you use? (pdworak)
Post by Toolman »
I use Valvoline and the most expensive oil filter that the parts place has, a cheap filter tends to have less fliter media.
http:/theeulogy.wirefire.com2003 Neptune Blue Moon and Tunes4 Speed AutoBluetooth Install(Wifes)2004 Torrid Red GTO Tinted WindowsBluetooth Install0-60mph in 5.2 seconds0-130mph in 22.5 seconds(Mine)
zionzr2
Post by zionzr2 »
currently have the purolator pure one.previous were factory, basic fram, ac delco, now sticking with the "Pure ONE"
Petrucci914
Re:
Post by Petrucci914 »
Castrol Syntec and PureONE. I like how people say they used AC Delco because that's what GM uses on their vehicles. People need to remember that the Vibe is basically 100% Toyota except for the CD Player which explains why mine is failing. I wouldn't have bought the vehicle if it didn't have a Toyota engine.
Cougar Vibe
Post by Cougar Vibe »
PureOne w/Mobil 1 (pre-Katrina).I do have a Denso on my Vibe right now, but as soon as I use up my stash of Toyota filters, I'm going to Purolator. It's not because the Denso is bad (it's actually quite good from what I read at BITOG), but Advanced Auto and Autozone run sales on Pure One's fairly regularly (I just bought four for $12). As for the AC Delco filter: I still don't understand why someone would go to their GM dealer to buy that thing. It's a rebadged Denso and it's ~$5 at your local Toyota dealer!
Bobssbase04
Post by Bobssbase04 »
Mobil-1 oil, and a Mobil oil filter
2004 Base Trix 5-speed Camcon with Boomslang harnessJP Performance header/high-flowcat/mid pipe comboMonkey Wrench flywheel ACT HD clutchMagnaFlow axle backAEM CAIEnergy Suspension motor bushings
pawkar
Re: What oil filter do you use? (Toolman)
Post by pawkar »
I use FRAM I think part 4967. This is the only brand of oil filter that I found for my Vibe and anyway this is the filter that the Opel dealer used last time. Here the Opel dealer is also giving service to Pontiac cars. Toyota has also a dealer here and I will check what brand of oil filter they are using.So far the car is fine and I am changing oil and oil filter in intervals of 6000 miles.
4azdmunky
Post by 4azdmunky »
K&N with royal purple 5W30
the1stacekiller
Re: What oil filter do you use? (4azdmunky)
Post by the1stacekiller »
ACDELCO with Mobil1.. but I am switching to Toyota F2 because the cost is about 50% less than buying from a GM dealer..cheers
- 2004 Pontiac Vibe Base 2 Tone Grey Goodness -
Psychobroker
Post by Psychobroker »
Quote, originally posted by Toolman »I use Valvoline and the most expensive oil filter that the parts place has, a cheap filter tends to have less fliter media.I believe AMSoil's SDF-10 is more expensive, but they carry 12,500 change intervals. I change my AMSoil oil & filter @ 10kmi anyway. SDF's replacement, the EAO line, is supposed to outperform everything else out there, and carries a 25k mile recommended change interval. I'm going to pick up a couple of these in the next few months, and push my oil & filter change intervals to 15k. link: https://www.amsoil.com/storefront/eao.aspx
Danski
Re: What oil filter do you use? (13Vibe03)
Post by Danski »
Hi I use Mobil-1 full sintetic oil, and a Mobil high preformers oil filter (the filter cost $11.00)
truckdriver402
Re: Re: (Petrucci914)
Post by truckdriver402 »
Quote, originally posted by Petrucci914 »Castrol Syntec and PureONE. I like how people say they used AC Delco because that's what GM uses on their vehicles. People need to remember that the Vibe is basically 100% Toyota except for the CD Player which explains why mine is failing. I wouldn't have bought the vehicle if it didn't have a Toyota engine.Ahh, yes. I had a dealer try to sell me a Vibe, and I didn't really want it just because it was a domestic. Once I researched it and saw that it was pretty much a Toyota everything, I bought it.
Whelan
Re: Re: (truckdriver402)
Post by Whelan »
Toyota OEM filter with Castrol GTX non synth.
2012 GLI Autobahn 6MT
truckdriver402
Re: Re:
Oh, and I use Purolator Pure One oil filters. I've used Pure One on everything I've owned.
NUBlackshirts
Post by NUBlackshirts »
I'm using Castrol Syntec 5w-30 and a Purolator PureOne filter.
'04 Frosty GT <---Click here!Tein S-Tech springs; Tokico HP struts;Progress rear sway bar; DC Sports strut tower bar;Scion TC wheels; K&N Typhoon intake;GG Racing ground wires; JAW voltage stabilizer;FilterMAG SS-250; Militec-1; Sirius Satellite Radio
Daox
Post by Daox »
I use Purolator Pure One and Mobil 1 synthetic.
Matrix MPG Build Thread
mspalmer
Re: (Daox)
Post by mspalmer »
Mobil-1 5w-30 with whatever filter the Pontiac dealership is using. You know, I should ask them someday which one they use.Mike
2005 Platinum AWDMoons and TunesXM RadioLLumar Window TintingWeathertech ventshauling my Taylor 410 w/Fishman pickup and Gibson SG guitars
VivaVibe
Post by VivaVibe »
Using Purolator PureOne #PL14477 and Mobil-1 5w30 full synthetic
2004 Base Shadow MonotoneMoon-n-Tunes, Power Pkg16" Alloys, AT, ABS, Side Air-bagsPin-stripe, 30% Tint, Fat exhaust tipMy GenVibe Garage
2006_Salsa
Re: What oil filter do you use? (VivaVibe)
Post by 2006_Salsa »
M-103
Sublimewind
Post by Sublimewind »
If ya'll are really interested in the skinny on oil filters, stop over at http://www.bobistheoilguy.com/ and check what they say about your oil filter... and oil for that matter... Much info over at BITOG, almost to much....
