huh i dont think the hertz place ever rotated the tires i use, the back ones have like 90% and the fronts are lik 60%....something like thatoh yea, i have a 2004with 30k miles on it now. i will neet to rotate these but i need some stands or jacks. any tips on this? or ill have to drive to the cities
I just ran into this problem. If you have a lowered vibe go for every oil change. if it is stock height go for every other oil change. so 3,000K lowered, 6,000K stock height. Trust me I just ran through my stock tires on 2 rotations and only 18K on the car. It is an 05 vibe. the guy i got the tires from is a expert on auto-x tracks and knows his stuff about tires. He is the only one around here I trust with anything.
2005 Base Vibe W/ moon and tunes , piaa headlight/foglight bulbs, tein s-tech suspension, cosmo CAI, TRD quickshifter, ES motor mount bushings, magnaflow exhaust, RK sport CF roof rack caps, tinted windows, kenwood KDC-X589 HU/w remote Cardomain Page http://www.cardomain.com/ride/797307
I just did mine this week. Took two days because I painted my brakes too. I have one jack stand and used the car's jack also. If your just rotatine the tires one stand will do. Should take less than an hour to do all four.
Monotone Neptune, pow pac, 17" stock rims, K&N air filter, bumper guard, custom pedels, brake light cover, billet oil cap
just by feel is fine. most people dont owna torque wrench and no shops use them that I have been to except for the guy that gave me the info this weekend that I posted earlier. He is very particular when it comes to cars. Dude doesnt have a girl, just devotes his life to any car other than ahonda, he hates overated hondas.
I rotate mine every 5,000. Coming up on my first one with the vibe. I go back to front and cross the front to back. Also use a torque wrench. Your roters will warp if you do not.
Quote, originally posted by Digger »I rotate mine every 5,000. Coming up on my first one with the vibe. I go back to front and cross the front to back. Also use a torque wrench. Your roters will warp if you do not. I don't know if it's different for FWD, but for AWD you don't cross the tires when rotating (front to back on same side only).
I have AWD. I checked with my tire shop and he said to still rotate back to front and front criss cross to back. He did add unless they put cheep tires on it to start with.
Quote, originally posted by nortsr »Doesn't the manual show how to Rotate the tires? Usually it will cover both FWD and AWD????Yes, you're right...page 5-68:"Tire Inspection and RotationTires should be rotated every 5,000 to 8,000 miles(8 000 to 13 000 km).Any time you notice unusual wear, rotate your tires as soon as possible and check wheel alignment. Also check for damaged tires or wheels. See When It Is Time for New Tires on page 5-69 and Wheel Replacement on page 5-72 for more information.The purpose of regular rotation is to achieve more uniform wear for all tires on the vehicle. The first rotation is the most important. See Part A: Scheduled Maintenance Services on page 6-4 for scheduled rotation intervals.When rotating your tires, always use the correct rotation pattern shown here. Tires should only be moved from front to rear and rear to front on the same side of the vehicle. Do not include the compact spare tire in your tire rotation."
My shop guy said when I told him what the manual said : They must come with cheep tires. and, that rotation pattern will do the job but the criss cross will maximize tire life. every tire will be on every axel at least onece every 4 rotations.
My 05 AWD came with Eage GS-A's. I think they're directional and you're not supposed to criss corss directional tires. I just did min at 5,000 miles and went front to back.I briefly owned a Subaru Forester and the owners manual prescribed rotating them front to back.
RSA tires are NOT directional. And a forester has a different rotation because of it's AWD system. The AWD vibe should not use the same rotation as the forester.
Digger,I know what the owners manual and everyone here says about rotation but the more I think about it, your tire guy has a good point about criss crossing. I think it's common sense that you'd definitely get even wear and if you don't have directional tires, what's the harm?
Last time I looked at my RSA's they were stamped "directional" - I've rotated my tires four times now - always front to back as the manual indicated.I bought a pair of jackstands and a 2 ton floor jack from sears for ~$100. It was one of the best things I've put in my garage - besides my two vibes.
I know this is an old thread, but I didn't want to start a new one. I've never rotated the tires myself. Always thought it would be more of a hassle than what it was worth someone else to do. Is there an easy way to rotate the tires? If you are just going front to back and back to front, that's easy, but what if you want to criss cross?
