I'm installing my Tein H-Tech springs. Got the fronts done, now having a problem with the rear.When the new spring was re-installed on the shock, the top part of the assembly tilts forward dramatically (see picture). This is the only way it seats. The assembly is oriented in relation to the base of the shock as before (i.e., no rotation).Is this correct??? Maybe when the weight of the car presses down it will straighten out, but it's going to be a real nightmare getting the shock back on the bolt to the rear suspension.
