Changing file name?
wicked1981
Changing file name?
Post by wicked1981 »
Ok so Im ok wih computers but not enough. So here is my question Im sure someone will know this one. I was searching for a song online and found a site that I believe you can download the whole album thats nice because the album wont be out till Oct 10th. My question is the guy that posted the link says I have to change the file to an .rar file. How do I do that? I clicked the properties tab on the download and it shows up as a HHC File how do I change it? HELP!
Sputnik
Re: Changing file name? (wicked1981)
Post by Sputnik »
I usually just right click and select rename and then rename it with the new file extension.
GenVibe Global Moderator
wicked1981
Re: Changing file name? (Sputnik)
I trie that but see the properties box it says its a HHC file. What does that supposed to say? It supposed to be a sound file right? Howdo I change that?
millster
Post by millster »
Open your My Computer, go to Tools, Options, select the View tab.Uncheck the "Hide Extensions for Known File Types" box.That will allow you to change the extension of the file.After you uncheck that box, you should see the filename as Warren.rar.hhc.Just remove the .hhc part.Once you have done that, you'll have to "un-rar" the file with a program such as WinRar.http://www.win-rar.com/start.htmlNote that I am NOT advocating music piracy, but I won't start into that debate.
-Millster-
2006 Toyota Matrix XR
1995 Saab 9000CSE 2.3T
wicked1981
Re: Changing file name? (millster)
Quote, originally posted by millster »Open your My Computer, go to Tools, Options, select the View tab.Uncheck the "Hide Extensions for Known File Types" box.That will allow you to change the extension of the file.After you uncheck that box, you should see the filename as Warren.rar.hhc.Just remove the .hhc part.Once you have done that, you'll have to "un-rar" the file with a program such as WinRar.http://www.win-rar.com/start.htmlNote that I am NOT advocating music piracy, but I won't start into that debate. So thats how you do it. I had downloaded other files before that said to change the file type I just didnt know how. Im downloading er.. buying WinRar to do the second part. Thanks for the help.
wicked1981
Quote, originally posted by millster »Open your My Computer, go to Tools, Options, select the View tab.Uncheck the "Hide Extensions for Known File Types" box.That will allow you to change the extension of the file.After you uncheck that box, you should see the filename as Warren.rar.hhc.Just remove the .hhc part.Once you have done that, you'll have to "un-rar" the file with a program such as WinRar.http://www.win-rar.com/start.htmlNote that I am NOT advocating music piracy, but I won't start into that debate. So thats how you do it. I had downloaded other files before that said to change the file type I just didnt know how. Im downloading er.. buying WinRar to do the second part. Thanks for the help. Either way Im buying the CD when it comes out.
millster
Post by millster »
That's a common trick, actually. Some ISP's will block hosting of RAR files because they're so commonly used for piracy. It's a good way to skirt email attachment filters too.
-Millster-
I never would have thought of that. Every windows box I get on I go into explorer, configure it to show file extensions, show system or hidden files, set view details, and set all folders like the current one. Really bugs me to have Microsoft think I can't be trusted to see the whole file name.
