I guess I didn't check hard enough, because it was the Gauge fuse (10A, under the dash). I got out the ohmmeter and checked every friggin' fuse until I found one without continuity.So, I replaced it, turned on the ignition, flipped the DRL switch and POP -- blew the next fuse. Hmmm...checked my wiring again. Guess what? The wiring was wrong! AND, this was the same setup that was shown at
http://dalenet.com/matrixvibe/In the picture below, the red/white wire at pin 12 in the DRL connector is split and each lead is then connected to the switch. The labels in the picture are incorrect as to how they connect to the switch, however.I don't have the energy to draw a schematic, but let me assure you, this is how the leads are to be connected:1) Ground wire to any ground (if you have a 12v lighted switch).2) Load to the wire coming from the DRL connector.3) Power to the wire running up into the dash.This is all moot is you are using an unlit switch.
