Delco factory XM radio menu or hack?
Josh
Post by Josh »
Has anyone found a menu in the XM radio? or a way to block channels without calling XM?
Re: Delco factory XM radio menu or hack? (Josh)
You can't block XM channels without calling XM even with the XM-branded equipment. That's not a shortcoming in the GM factory setup, it's just the way the system is right now. Some of the XM equipment can keep a channel from showing up in the scroll menus, but it certainly doesn't block the channel, as one could direct tune to it.As for a menu, what kind of menu are you looking for? Do you mean a channel guide?
Josh
Re: Delco factory XM radio menu or hack? (ragingfish)
Post by Josh »
Maybe a signal strength meter...you know, stupid stuff like that...
Jahntassa
Post by Jahntassa »
Probably not. I don't know if you can even get that with the XM Direct unit for aftermarket radios..
