lost a hex screw :(
21Rouge
lost a hex screw :(
Post by 21Rouge »
I was removing the hex screws securing the radio unit. All was fine except for the bottom right which is postioned far back. I had loosened it with a phillips and was reaching in blind to remove it, pulling it out between my fingers and it fell...somewhere! I didnt hear it drop and the screw with washer isnt small. It didnt come out on the carpet of the passenger side. I'd prefer not to take out all the trim below to track it down. Can an suitable screw and washer be easily obtained from a hardware store? Any worries leaving the original in the back?
Jahntassa
Post by Jahntassa »
Probably fell down behind the center console..you might be able to reach for it where the carpet ends up by your feet.. If not, it shouldn't be a problem..Yeah, just take one of the other screws with you to kinda match it up. It can be a little longer if needed.
21Rouge
Re: (Jahntassa)
Post by 21Rouge »
Quote, originally posted by Jahntassa »Probably fell down behind the center console..you might be able to reach for it where the carpet ends up by your feet.. .I even drove around a bit hoping to jostle the screw to have it fall all the way...hopefully getting it to come out on the passenger side on the floor.Quote, originally posted by Jahntassa »Yeah, just take one of the other screws with you to kinda match it up. It can be a little longer if needed.Why is the original brass?
Re: (Boxgrover)
It's not brass. It is steel, but it is anodized, or some such similar corrosion prevention coating.
mcgusto82
Re: (joatmon)
Post by mcgusto82 »
remove the lower shifter console. it comes off fairly easy. (first timers). i dropped mine in the first time i removed the radio too. didn't find it untill i had to remove the shifter console. then i went ahead and put it back.
