Different tires? pros/cons
Nemo6321
Post by Nemo6321 »
Since I am a total n00b, I have a question. Becasuse Vibe is front driver, does it pay to have front wheels wider than back ones? What would happend?
Sub-Vibe-R
Re: Different tires? pros/cons (Nemo6321)
Post by Sub-Vibe-R »
It will look very stage, wider tire in front. If you want to have wider tire, change the 4 tires. with that, will be also easier for tire rotation.
Flip-Side
Post by Flip-Side »
This is the only time you would want wider wheels on the front. Drag racing. Traction is horrible in wet/snow/dirt.
MadBill
Re: Different tires? pros/cons (Flip-Side)
Post by MadBill »
Since my bare bones base Vibe does not have ABS, I was toying with the thought of using taller & wider rears, just for the Street Machine image. Probably not a good idea though, as it would screw up cornering balance and preclude tire rotation...
