is this the RIGHT booster cable for VIBE ???
dennisdrive
Post by dennisdrive »
Hi everyone ;I was just wondering what kind of booster cable to get for the vibe .There are so many in the stores .I got a 8 guage ; 12 feet booster cable manufatcured by Woods from Superstore today . Will this do the job in case needed ??
2004 Salsa Base ATPower PackageSports Package Rear Mid gate & Upper Spoiler.
Mavrik
Re: is this the RIGHT booster cable for VIBE ??? (dennisdrive)
Post by Mavrik »
I've just used regular booster cables on mine the one time I had to boost it.
the_nite_owl
Post by the_nite_owl »
I do not think you could really have a wrong booster cable.The gauge of the cable is mostly related to their length. The longer the cable the higher the gauge wire you want (wire sizes use lower numbers for thicker wire).The thickness of the wire also determines how much current you can safely put through it but 8 gauge is nice and thick and I could not imagine you needing to pull more current through it than it could handle, at least not when using it for it's true purpose of jump starting or boosting another car.Sometimes it is important to get a set with the right clamps on the end. Some cables have clamps that let them attach more readily to side post batteries. Some clamps are so cheaply made that they twist and distort and do not clamp to the terminals well.Quote, originally posted by dennisdrive »Hi everyone ;I was just wondering what kind of booster cable to get for the vibe .There are so many in the stores .I got a 8 guage ; 12 feet booster cable manufatcured by Woods from Superstore today . Will this do the job in case needed ??
Re: is this the RIGHT booster cable for VIBE ??? (the_nite_owl)
Quote, originally posted by the_nite_owl »The gauge of the cable is mostly related to their length. The longer the cable the higher the gauge wire you want (wire sizes use lower numbers for thicker wire).the longer the wire, the bigger the wire, which means a lower numbered gauge of wire, but 8 ga for 12' cable s should be plenty.Just be absolutely sure you get the polarity right, red (+) to red(+), black (-) to black (-). damage can result if you get them crossed.Hope you never need them for your vibe, just to help out otherr people. !
