Wide rim fitment question
Smokin' Rubber
Post by Smokin' Rubber »
Will a 8.5" rim running 235/40/18's +35 offset fit in the wheel wells without rubbing stuff?
nismo
Re: Wide rim fitment question (Smokin' Rubber)
Post by nismo »
Ask Madbill. He did some really wide wheels on his Vibe. So, yeah. Send him an email or somethin and go from there.Inder
Smokin' Rubber
Re: Wide rim fitment question (TRD4reel)
His were 10" rims and his offset was 32 because he made an adapter, different situation tho
MadBill
Post by MadBill »
I have 17" x 10" wheels with ~ 34 mm offset and 275/40 tires on my Vibe. With a 1 -1/2" drop, I get a little scuffing of the rears against the outside fender lips on big dips, but 235s would be 20 mm (0.79") narrower per side, so you should be fine.
Smokin' Rubber
Re: Wide rim fitment question (MadBill)
Even with a 2.3 inch drop?
MadBill
Post by MadBill »
Lowered or stock, the worst case is when you hit the bump stops on a big dip with a full load. However, my sidewalls barely catch the fender lip. Even 1/4" more clearance would eliminate the contact. I plan to grind a bit off the lips, but haven't got to it yet.
