Glove Box Light?
a58vette
Glove Box Light?
Post by a58vette »
Apparently there is no glove box light. So i am going to install one and am just curious if anyone has done this before and if so how they did it and pictures if available.
Sub-Vibe-R
Re: Glove Box Light? (a58vette)
Post by Sub-Vibe-R »
You're wright, there's no glove box light. I haven't put one in mine but I'm going to install some light under the dash, to light our foot.
jeffgtx
Post by jeffgtx »
i want to do this now. any one else done it?
JeffGTX's Shades Of Gray Pontiac Armada:Cool: 2008 Solstice GXP ConvertibleSly: 2009 Solstice GXP CoupeMaverick: 2009 G8 GXP
damronjr
Re: Glove Box Light? (jeffgtx)
Post by damronjr »
I shouldn't imagine that it would be too hard. With all the leds and such being run lately, a light with a switch shouldn't be too difficult. If you want it to turn on when you open it, that might be a little harder. I'm sure there'll be some inputs on this.
BruiserVibe
Post by BruiserVibe »
I plan on putting lights in the glove box and also in the small storage compartment on the driver's side. I'm going to wire them up to turn on when they open by mounting a rocker switch nearby so that when the door is opened, it flips the switch, and when closed, flips the switch again. I'll post pics when I get it done.
Altus
Post by Altus »
I've done it - no pics (sorry) - but it was no big deal. Found some LED accent lights, mounted them inside the glove box, and wired them to the wire that powers the accent lights for the cigar lighter. I added a micro switch to the door for the on/off action.Easy, quick, and relatively painless....
jeffgtx
Re: Glove Box Light? (Altus)
Post by jeffgtx »
do you have part number or a link for where the micor switch can be had?
Wimperdink
Re: Glove Box Light? (BruiserVibe)
Post by Wimperdink »
use a pin switch or a reed switch for clean look. Need one I have lots of both.
03 AWD VibeMoons & ToonsPower GroupEchomaster Reverse SensorComputer Desk (for laptop gps)Window Vent Shades5% tint XM Roady 2Audiobahn Amp w/10" Infinity
jeffgtx
Re: Glove Box Light? (Wimperdink)
Post by jeffgtx »
well since youa re offering whats the difference? any pics, or alink to what they look like?thanks
Wimperdink
reed switch variations... - http://www.mouser.com/catalog/622/1115.pdfbetter yet... - http://www.mouser.com/?Ne=300&...FieldThat will keep ya busy for awhile
jeffgtx
Post by jeffgtx »
ok, let me see if i can pass teh wimperdink switch quiz...reed switch: magnetic SPST such that in the presence of the other side, turns off or onpin switch- the kind with the 'post' sticking out and when the door pushes it in when closed and turns out the light?did i win?i guess i would like the reed type and then i can hook it up to a white LED setup right inside.do you have one i could buy?Jeff
Wimperdink
hey jeff check your IM's
jeffgtx
Post by jeffgtx »
IM back atchya!
Mase
Re: Glove Box Light? (silverawd26)
Post by Mase »
I've done it in both the Matrix and Corolla.All it took was a momentary switch (normally closed), a 4000mcd led, resistor, and about 24 inches of wire.I'll try to take pics later.
Atomb
Post by Atomb »
just a thought...LEDs last for tens of thousands of hours and are pretty cheap. why do you need a switch? why not have it connected to the dash light circuit so that it's on whenever the dash lights are on? it may even look interesting to have a red or blue or whatever glow surrounding the glove box door. reminds me of pulp fiction for some reason!
ToolGuy
Post by ToolGuy »
I was going to do this but it got dropped...However I do have the lamp, socket and a hand made bracket ready to go when I do pick the project back up. I am using an old glove box switch and socket I picked up from a salvage yard many years ago; had it laying around in my parts dept!It has a door pin switch and there is a perfect spot on the top of the opening which meets the door so it will open and close or come on and off perfectly! No pics now but I can take a pick of what I do have already...
