Your drive in to work this morning (Michiganders)
Indiana, Iowa, Illinois, Michigan, Minnesota, North & South Dakota, Nebraska, Wisconsin
yank dini
Post by yank dini »
How did you Vibe hold up on our first real Snow day? That is if you don't live in Port Huron
Michael Matola
Re: Your drive in to work this morning (yank dini)
Post by Michael Matola »
Held up great. This was my first drive in snow in the new Vibe and I was pleased. Back wheels went slippy for a split second going up a hill in Ann Arbor, but other than that it was fine. (OK, I could have avoided that hill, but I wanted to see how well the Vibe would take it.)I take M-14 to Ann Arbor and it was a mess. Snow wasn't bad -- only an inch or so. But cars were backed up for miles. I bailed at Ford Road, which turned out to be just as bad as M-14 in terms of back-up. What's normally about a 40-minute commute ended up about an hour and 45 minutes this morning.
hesredbird
Post by hesredbird »
It was white knuckle city in the Flint area. The Vibe disapointed me. Tire spinning and front end "wandering" was bad. Braking was not the best either.
Red
Vibe
Post by Vibe »
WEll-I wasn't either impressed or dissapointed--it was so so. But what do you expect ---its not a 4 wheel drive Monster,so I can say it was ok. I thought about my 4 wheel drive Jimmy I got rid of for the Vibe. But up here they do a pretty good job on the roads.But all things considered I still love my VIBE. James
jeremyfattire
Post by jeremyfattire »
I went from a 4door, 4wd, Yukon to a six-speed front wheel drive car.It took some serious getting used to in the snow, but I made it. Thecar does not make it up the steeper hils very well at all, but by the way this winter is starting off, I'll be an expert in Jan.
Vibe-rate
Post by Vibe-rate »
Well, I got rid of a 4WD Explorer to get the Vibe, since I think I used the 4WD system maybe twice in two years. The Vibe isn't "great" in the snow, but it's adequate (would probably be more than adequate, if I'd get rid of the Conti's). I managed to stall it once (1st time) coming up to a light - I normally start braking first, then push in the clutch once I'm close to a stop. This time, I found a patch of ice, and my "light braking" turned into "lock up the wheels". Lock up = instant stall.
2003 Salsa Base5-spd, Power, M&T
